Clutch/Flywheel combo?
Old May 22, 2008 | 04:39 PM
B18cFreak's Avatar
Default Clutch/Flywheel combo?
Hey there. I have a jdm b18c in a daily driven eg. I was just woundering what the best cluch and flywheel combo would be for about a 205 hp daily driven car for occational track days. And also some recomended maufacturers.
Old May 22, 2008 | 04:55 PM
Boosted_01 R's Avatar
Default Re: Clutch/Flywheel combo? (B18cFreak)
Exedy Stage 1, with ACT flywheel. Had that combo, when I had my B18C Civic back in 2006. Tracked it a few times, never had a problem.
Old May 22, 2008 | 05:00 PM
B18cFreak's Avatar
Default Re: Clutch/Flywheel combo? (Boosted_01 R)
was that the 8 lb. flywheel you used?
Old May 22, 2008 | 05:07 PM
MK Ultra's Avatar
I had an ACT HD/SS with a JUN flywheel for 9 years without a single problem. I loved the pedal feel and response that combination yielded. It grabbed hard every time, and in most situations was actually easier to drive than the stock setup, despite the stiffer pedal.
However, next time around I will probably buy an ATS (or whatever they're calling it these days) single-disc carbon setup. They're fully rebuildable and supposedly have a near-stock pedal feel.
Old May 22, 2008 | 05:19 PM
B18cFreak's Avatar
Default Re: Clutch/Flywheel combo? (MK Ultra)
hmmm. i gonna have to look into that. as long as it is relyable, not to stiff pedal feel for traffic, and perform well. 9 years sounds like a lot of abuse for a clutch too.
Old May 22, 2008 | 05:28 PM
SuckMyDOHC's Avatar
I have a Competition Clutch Stage II clutch and 12lbs flywheel in my 94 ls with a B20 swap and it feels great. Stiffer than stock but not too stiff and the grab is amazing
Old May 22, 2008 | 05:34 PM
B18cFreak's Avatar
Default Re: (SuckMyDOHC)
well i was leaning tward a 8 lb flywheel. i will make a sacrafice for some extra TQ. but it should be ok in terms of longevity right? like it wount warp easily lets say for maybe a act prolite flywheel? then maybe like a stage 1 or2 clutch on top of that may be a decent. nothing over stage 1 or 2.
Old May 22, 2008 | 08:01 PM
Default Re: (B18cFreak)
Get the street ACT flywheel (what was on the civic), 10.5LB i believe. Your gonna need the extra rotating mass. Also ACT is also very good, Heavy Duty pressure plate with a unsprung 6 puck disk is also good. Slightly harder pedal than the exedy, Both worked well.
Old May 22, 2008 | 09:36 PM
SuckMyDOHC's Avatar
Default Re: (Boosted_01 R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted_01 R &raquo;</TD></TR><TR><TD CLASS="quote">Get the street ACT flywheel (what was on the civic), 10.5LB i believe. Your gonna need the extra rotating mass. Also ACT is also very good, Heavy Duty pressure plate with a unsprung 6 puck disk is also good. Slightly harder pedal than the exedy, Both worked well.</TD></TR></TABLE>
I highly recomend not going with an unsprung disc for daily driving. You're better off with a sprung disc.
Old May 22, 2008 | 09:50 PM
Doostur's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuckMyDOHC &raquo;</TD></TR><TR><TD CLASS="quote">I have a Competition Clutch Stage II clutch and 12lbs </TD></TR></TABLE>
Great Combo
Old May 23, 2008 | 04:10 AM
PrinceAli132's Avatar
Default Re: (Doostur)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doostur &raquo;</TD></TR><TR><TD CLASS="quote">
Great Combo</TD></TR></TABLE>
I just installed this combo this past weekend; Competition Stage 2 with the 8 pound flywheel. And so far I really like it.
The only thing that I am not a fan of is that the pedal is a lot softer (which is not neccessarily a bad thing). Its just that I came from a ACT HDSS setup and the medal was much firmer.
Ali
Old May 23, 2008 | 12:47 PM
Doostur's Avatar
Ya I got the same flywheel with a stage 5 cc sprung and not pricey at all!
norcalB18
Transmission & Drivetrain
Dec 12, 2009 02:53 PM
eg4life1202
Dec 29, 2006 11:28 AM
jdm ek9 101
Jun 28, 2006 03:59 PM
GSR_Hacker
Dec 4, 2002 01:17 PM
Big Teggie
Sep 9, 2001 02:51 PM
