ecu harness problem
Old May 22, 2008 | 04:05 PM
jkinros's Avatar
Default ecu harness problem
I tried to run diagnostic in my car today and guess what, the plug does not work. We checked his computer to another car and its fine. This is also the same harness/plug that plugs me into the ca emissions computer,right?
So where/how do i start to trouble shoot this problem?
I admit the car had been very neglected, and has almost been stolen a number of times. They'd ripped out the column and under the dash and might have pulled some wires.
The car is stock. It's been running well till recent. I just want to get it back to great running condition and take better care of my 99 hatch Please help
Old May 22, 2008 | 04:16 PM
raidacaipo's Avatar
Default Re: ecu harness problem (jkinros)
same thing happen to me.. I brought my car to autozone to use their p scanner.. and it says error.. i wanna know too..
Old May 22, 2008 | 05:15 PM
likwidchz's Avatar
Default Re: ecu harness problem (raidacaipo)
well your going to have to let people know if its OBD1 or OBD2
either way the pinouts for obd1 are very easy its 2 wires
Obd2 is a bit different, they have a couple more wires, although you could relocate the pinouts off the ecu directly and attach like a 3-4 foot cord off the ecu so you can route the thing where ever you want.
Old May 22, 2008 | 05:18 PM
JEGD16Z6's Avatar
Default Re: ecu harness problem (likwidchz)
yea when my diag plug did not work on my OBD I i just grounded out the pin for the diag on the ECU.
Old May 22, 2008 | 05:23 PM
likwidchz's Avatar
yeah that probably works too as the honda ecu's have sensor ground and also normal ground.
your simply connecting D4 + D21/D22 together that gets the CEL on the dash to blink error codes.
Old May 22, 2008 | 06:55 PM
raidacaipo's Avatar
I thought only obd2 cars can be used with the scanner port??
Old May 22, 2008 | 07:07 PM
likwidchz's Avatar
Obd1 cars can also that's what the Datalink connector is for its, serial based its just not widely used as obd2 scan tools.. Pin D7 on obd1 ecu's
Old May 23, 2008 | 02:55 PM
jkinros's Avatar
Default Re: (likwidchz)
its obd2 Can you talk more about the relocating the pin outs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by likwidchz &raquo;</TD></TR><TR><TD CLASS="quote">well your going to have to let people know if its OBD1 or OBD2
Obd2 is a bit different, they have a couple more wires, although you could relocate the pinouts off the ecu directly and attach like a 3-4 foot cord off the ecu so you can route the thing where ever you want.</TD></TR></TABLE>
Old May 24, 2008 | 09:03 AM
likwidchz's Avatar
well searching the forums hear will show you complete obd2 pinouts.
then looking on your obd2 connector in your car should give you an idea of which pins do what. From experience I know if you short that connector the fuse for the radio blows which tells me that theres a 12v lead thats wired to the radio thats also included in your obd2 connector, i believe its something like 3-4 wires..
Tehknein
Jan 2, 2015 02:30 AM
ek coupe
Feb 19, 2009 09:05 AM
93hatch_minime
11
Feb 11, 2009 11:16 AM
dizzyek
Feb 7, 2006 02:58 PM
civic_ekek
Aug 10, 2005 10:14 PM
