obd1 to obd2
obd1 to obd2
ok i have a obd2 ls motor with the wiring harness will it clip up to my stock wiring in car but not the stock motor harness i know that or do i have to re pin everything
Re: obd1 to obd2
Re: obd1 to obd2
you're goign to run an OBD1 ECU i'm assuming? depending on your trim(also assuming you have 93 hatch) you may need to run wires for the 4 wire 02. you only need to use one of them.
Re: obd1 to obd2
Re: obd1 to obd2
Seagull Management
Re: obd1 to obd2
The CXs used a single wire O2 sensor, The LS and most civics use a 4 wire O2 sensor. You will need to run 2 wires from the ECU to the shock tower. (the signal wire is already there, and the 12v power wire for the heater circuit is only in the engine harness, which you are using from the integra.)
