Need help, car overheating after hose change
Old May 22, 2008 | 02:29 PM
RDAYA0's Avatar
Default Need help, car overheating after hose change
Alright guys one of my cooling hoses from my block going to iwhat i think is the water pump was cracked and was leaking coolant, i replaced it with a brand new one and when i start the car it overheats, im trying to bleed it by filling the coolant base to the top of the filler neck, cracking open the radiator cap, and then starting the car but it still overheats and no coolant is comming out of the bleeding spot.
Old May 22, 2008 | 03:33 PM
hard_boiled_EG's Avatar
Default Re: Need help, car overheating after hose change (RDAYA0)
only thing i can think of is that your thermostat might be stuck close?? try doing those last three steps backwards also...expect the overheating because that's how i do mines..... o yea that let the car cool down first...
Old May 22, 2008 | 03:40 PM
RDAYA0's Avatar
Default Re: Need help, car overheating after hose change (hard_boiled_EG)
ok i will it was fine before the change
Old May 22, 2008 | 05:33 PM
elektronsi's Avatar
you might just have air bubbles in there, you can do it in your driveway by starting the car, open the radiator cap, and fill with fluid a little bit at a time, expect coolant to bubble out as it works its way through the motor.
p.s. start with the engine cold
2000eK_cIvIc
13
Apr 19, 2011 05:04 PM
cheeksnme
Dec 27, 2006 09:48 AM
Cashis Lee
Apr 28, 2005 04:29 PM
NeXtLeVeL_TyPe_R
Jan 6, 2004 07:09 AM
migs
Dec 20, 2002 06:14 PM
