Titanium Retainers Advice
Old May 22, 2008 | 01:52 PM
Spec R_GSR's Avatar
Default Titanium Retainers Advice
Hello Guys im rebuilding my LS/V motor and i got a set of CTR cams that i plan on using i bought all new seals and a set of Type R valve springs as for retainers i had a set of Skunk 2 retainers lying around from a previous build. My question is can i use these retainers without any problems and if so what benefits and be had from this setup.
Old May 22, 2008 | 02:02 PM
Str8EJ's Avatar
they are lighter than stock (?)
ti vs steel debate will have you running in circles. you'll need to make up your own mind regarding benefits/risks, rather than rely on advice from strangers.
Old May 22, 2008 | 04:59 PM
UncleD's Avatar
Default Re: (Str8EJ)
I don't have a problem with TI retainers if they are a snap-fit design with the valvespring, like the RM line of VT is. If the retainers aren't designed to work with the specified spring, I don't think I would use them.
Old May 22, 2008 | 05:11 PM
DonF's Avatar
Default Re: Titanium Retainers Advice (Spec R_GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spec R_GSR &raquo;</TD></TR><TR><TD CLASS="quote">Hello Guys im rebuilding my LS/V motor and i got a set of CTR cams that i plan on using i bought all new seals and a set of Type R valve springs as for retainers i had a set of Skunk 2 retainers lying around from a previous build. My question is can i use these retainers without any problems and if so what benefits and be had from this setup.</TD></TR></TABLE>
Are they used? If so, you have answered your own question.
Old May 26, 2008 | 03:47 PM
Spec R_GSR's Avatar
Default Re: Titanium Retainers Advice (DonF)
they're brand new
Old May 26, 2008 | 05:22 PM
UncleD's Avatar
Don's gonna give you your best answer, he might chime back in.
Spec R_GSR
May 22, 2008 07:39 PM
del_slow
Feb 1, 2008 07:07 PM
Deetz
Feb 26, 2004 02:16 PM
klnteg
19
Nov 18, 2003 01:48 PM
Dan1krzysi
Jan 31, 2003 02:57 PM
