93 ej coupe...no brake lights or horn
Old May 22, 2008 | 12:31 PM
jdmeg1075's Avatar
Default 93 ej coupe...no brake lights or horn
i have no brake lights or horn....i checked the bulbs and the fuse and they are all ok..... could it be a ground problem?where is the ground located for the brake lights?could that cause the horn to not work also?
any advice would help at this point......let me know asap...plz
thanx
Old May 22, 2008 | 01:06 PM
LANCEalot's Avatar
Default Re: 93 ej coupe...no brake lights or horn (jdmeg1075)
my car doesnt have a horn either haha sucks.
Old May 22, 2008 | 02:19 PM
bigsyke's Avatar
your fuse is blown because you ahve a short in a wire.
Old May 22, 2008 | 02:29 PM
h2392si's Avatar
Default Re: (bigsyke)
Have you checked the relays are well? Try that and double check the fuses from the bottom of the steering column and also under the hood.
White_EG1
10
Feb 18, 2019 01:07 AM
Hakuna33
Nov 30, 2009 12:56 PM
keepitngga1
Jul 18, 2008 10:26 PM
cmyrex
Jul 12, 2006 04:27 PM
dankies
Feb 8, 2006 08:32 PM
