Jerky steering?
Old May 22, 2008 | 09:00 AM
mattvivsound's Avatar
Default Jerky steering?
I have a ’97 Civic EX coupe and something is up with the steering system.
When I am under 30 mph the steering feels fine, but once you get up to highway speeds the steering become very jerky when you’re turning in a turn. When you go to straighten the wheel when exiting the curve it feel like I am turning against the grain.
I can take my hands off the steering wheel, and the civic will drive straight, the wheel doesn’t shake or vibrate when I am on the brakes.
I am sure I am describing the problem as best as I can, but ask questions and I’ll answer.
Old May 22, 2008 | 09:28 AM
Andres-eh2's Avatar
different things come to mind...Tie Rods, Lower ball joints, bad LCA bushings. go under the car and check for torn bushing. Also check your axles.
Old May 22, 2008 | 09:52 AM
hatchling37's Avatar
Default Re: Jerky steering? (mattvivsound)
How're your struts? Leaking at all? Do you have power steering? How's the level? Do you have bubbles in the reservoir at all?
Edit: EX, so yes you do. Get the front end in the air by jacking it up on teh CA and give it a good front end shake, then get back to us.
Old May 22, 2008 | 10:32 AM
D16SohcVtec's Avatar
I'm thinking ball joints. My old hatch use to do that.
Old May 22, 2008 | 10:33 AM
Default Re: (Andres-eh2)
the axles are pretty new, within the last year or 15k miles. But I'll jack it up to night and wiggle everything.
PrettyMuchBoned
17
Apr 28, 2014 12:25 PM
cgap
Mar 22, 2008 01:30 PM
jessismiles
May 27, 2007 03:04 PM
TurboBumblBee
Apr 13, 2003 05:57 AM
jabroni95gsr
Feb 13, 2003 04:12 AM
