should i go LS VTEC
Old May 21, 2008 | 10:15 PM
2fast4urass's Avatar
Default should i go LS vtech
how much hp does a LS vtech have & would i need only the GS-R computer & head ???
Old May 21, 2008 | 11:09 PM
0LdsKooL's Avatar
I think you'll be around 160 and you'll need a ls V Tec kit, V Tec soleniod(sp), and gsr wiring harness.. If I'm forgetting something ppl plz help out
Old May 22, 2008 | 01:48 AM
J. Funk's Avatar
There is no set amount of power for a LS/Vtec. You need the head, ecu that you have to get tuned, and the conversion kit. That is the bare minimum. Go here for the rest https://honda-tech.com/zerothread/1812388
Old May 22, 2008 | 01:49 AM
ReallyPoorManTypeR's Avatar
Default Re: should i go LS vtech (2fast4urass)
id recomend 'LS VTEC" yes/// not ls vtech thats my cordless phone lolnah bro jp ...
but ls vtec if built right is pretty reliable...
if u could get ur self a gsr block...
throw a ctr head on it...runs like butterrrr
Old May 22, 2008 | 05:04 AM
fliped182's Avatar
I did the ls/vtec and its not worth it. I thought I could just slap on a new head and call it a day. I ended up having to bring the car to a shop and it took them 9 months to finish. THe project ended up costing around $7k. Had to replace the pistons with high compression pistons, get your rods shot peened, new intake manifold, dizzy, vtec solenoid, idle control valve, new ecu,headers, and some work at the machine shop. Your compression is going to be arround 11:1 which means your gas mileage is going to suck. You also will have to run premium fuel, and your car will not run right unless you let the car warm up for a couple minutes.
After I got the car back the engine shook violently, and had to get new motor mounts.
Do yourself a favor and just buy a type R engine and tranny, I wish I did.
Old May 22, 2008 | 07:05 AM
AlphaQup's Avatar
Default Re: should i go LS vtech (fliped182)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fliped182 &raquo;</TD></TR><TR><TD CLASS="quote">I did the ls/vtec and its not worth it. I thought I could just slap on a new head and call it a day. I ended up having to bring the car to a shop and it took them 9 months to finish. THe project ended up costing around $7k. Had to replace the pistons with high compression pistons, get your rods shot peened, new intake manifold, dizzy, vtec solenoid, idle control valve, new ecu,headers, and some work at the machine shop. Your compression is going to be arround 11:1 which means your gas mileage is going to suck. You also will have to run premium fuel, and your car will not run right unless you let the car warm up for a couple minutes.
Do yourself a favor and just buy a type R engine and tranny, I wish I did.</TD></TR></TABLE>
I guess some people learn the hard way. If done correctly, all your problems you've encountered can be easily avoidable. My LSV setup runs like a champ. I mash on it everyday too. No CEL's, No erratic idle, & purrs like a kitten.
Old May 22, 2008 | 07:38 AM
all-mtr-teg's Avatar
1. If it took them 9 months to finish that's a POS shop.
2. 7K for LS/Vtec, you got served, should have done the labor yourself
3. The Rods don't NEED to be shot peened
4. With a good tune you can get better gas mileage than before the build
5. The car can run smooth like stock if it's put together and tuned properly
6. If your mounts were bad the car would have shaken violently w/ the stock motor also
Old May 22, 2008 | 10:59 AM
Default Re: should i go LS vtech (all-mtr-teg)
i agreeeee my pormn type r runs like a [freak]n champppp!
Old May 22, 2008 | 11:03 AM
danjensen's Avatar
Default Re: should i go LS vtech (ReallyPoorManTypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReallyPoorManTypeR &raquo;</TD></TR><TR><TD CLASS="quote">id recomend 'LS VTEC" yes/// not ls vtech thats my cordless phone lolnah bro jp ...
haha i have that phone too
Old May 22, 2008 | 11:55 AM
P'cola GSR's Avatar
get a gsr block and type-r head and pistons, and you'll have a type-r thats stamped b18c1
trust me when i say it runs strong
Old May 22, 2008 | 12:02 PM
Mcdc2's Avatar
Default Re: should i go LS vtech (P'cola GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P’cola GSR &raquo;</TD></TR><TR><TD CLASS="quote">get a gsr block and type-r head and pistons, and you'll have a type-r thats stamped b18c1
trust me when i say it runs strong</TD></TR></TABLE>
Sure it may run strong but does it run reliable!?
Old May 22, 2008 | 12:05 PM
P'cola GSR's Avatar
Default Re: should i go LS vtech (Mcdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mcdc2 &raquo;</TD></TR><TR><TD CLASS="quote">
Sure it may run strong but does it run reliable!? </TD></TR></TABLE>
drive it everyday and just beat a sc Gt mustang the other day on type-r throttle body and manifold.
Old May 22, 2008 | 01:39 PM
IVE HAD MY SETUP FOR ABOUT 9 MONTHS STILL RUNNING THE SAME AS WHEN I GOT IT..
I GUESS IM JUST LUCKY..ALL I HAD WAS VALVE TERAIN AN ITS BEEN GOOD I RACE IT EVERY WEEKEND,..
LOL
Old May 22, 2008 | 06:49 PM
dc2ls-vtec's Avatar
My LS/V is great, if you didn't know what you were looking for, you'd think it was factory. I'll probably swap the bottom end for a b18c1 or c5 bottom. I don't like sweatin' it everytime I approach 7.5K. I'd recomment it to anyone, it is the cheapest way to add more power besides nitrous (if you know what you're doing) B16 heads are everywhere, LS/V's are commonplace. All the mystery has been taken out of building them.
For the guy who spent 9 months and 7k building one, you could have built an entire car for that. It sounds like you got taken for a ride. It's really not much more work than changing a head gasket.
Old May 22, 2008 | 09:51 PM
drive it everyday and just beat a sc Gt mustang the other day on type-r throttle body and manifold.</TD></TR></TABLE>
Did he know you guys were racing? I really doubt you took out a blown GT with basically a stock type R, unless the driver miss-shifted or some other malfunction occured
Old May 22, 2008 | 10:06 PM
Rickdrizzle's Avatar
I honestly like my gsr better than a poor man's R or lsv.
ThoRoughEG6
Apr 13, 2007 10:07 PM
helpmeplease
Oct 29, 2004 11:31 PM
shinji666
Aug 20, 2004 12:22 AM
xstalkrx
May 17, 2003 03:56 AM
