whats cost on installing a factory sleeve?
Old May 21, 2008 | 03:25 PM
stroker8950's Avatar
Default whats cost on installing a factory sleeve?
i have run across a GSR shortblock everything is in excellent condition exept for #1 cylinder hydrolocked broke the rod in half and took two chunks out of the bottom of the sleeve half the size of a quarter.
my question is has anyone had a factory sleeve reinstalled?
whats usual price on this parts and labor?
Old May 21, 2008 | 05:48 PM
I makes it RAIN's Avatar
Default Re: whats cost on installing a factory sleeve? (stroker8950)
LOL, again?
Old May 21, 2008 | 07:50 PM
Default Re: whats cost on installing a factory sleeve? (I makes it RAIN)
im just asking if anyone has done this
Old May 22, 2008 | 02:18 PM
Str8EJ's Avatar
i'm not sure you can have a single sleeve replaced with another stock one. the iron liner is cast in to the aluminum form, which is integral to the block itself.
pretty sure if you want to salvage the block, you'll have to get aftermarket, ductile iron sleeves installed after having the factory floating sleeves machined out.
post pics, if available. may be i'm misunderstanding.
Old May 22, 2008 | 06:01 PM
IN VTEC's Avatar
Default Re: (Str8EJ)
We had a shop try to do that, and it was suggested that the liner would lift out.
Tyler Dirden
Aug 31, 2013 09:16 PM
Funkmaster Ferio
Nov 20, 2005 05:29 PM
ah789454
Jul 25, 2004 07:44 AM
_Endless_
Mar 11, 2004 06:37 AM
rig9896
Oct 3, 2002 04:00 PM
