h22 smoking after rebuild?
Old May 21, 2008 | 03:06 PM
slowassBubble's Avatar
Default h22 smoking after rebuild?
yeah i have a h22a4 swapped in my 93 civic, i just had it rebuilt, new piston rings, new rod bearings, new hgasket, changed all 4 pistons with used ones...anyways i had it rebuilt because it was knockin and eveyone told me it was pistons at the wrist pin, i had it rebuilt and the knockin was still there so i was like WTF??? so the other day i decided to hook a vaccum line to my egr valve(didnt have a vaccum on it when i bough the car) and the noise went away. so now i figured out that my egr valve was the problem all along and that i wasted my money on a rebuild and the worst thing now is that now my car smokes pretty bad?? i have no idea what its from, it doesnt seem to be burning any oil nor mixing with coolant or anything but the oil seems to smell like fuel a lil bit? the smoke it like a white/grayish color and it always smoke, it doesnt get better or worst as it warms up or i drive. so my question is does anyone have any idea of what it can be....could it be my egr valve or is it because its breakin in?? any help would be appriciated thnks
Old May 21, 2008 | 03:07 PM
Apex1972's Avatar
Default Re: h22 smoking after rebuild? (slowassBubble)
why in the hell would you use used pistons. FTL
Old May 21, 2008 | 05:17 PM
H23VTECBB1's Avatar
Default Re: h22 smoking after rebuild? (Apex1972)
Ok no need to hate because he reused the old pistons,He didnt ask for you to come in and make a lame comment. Back to your question, yes reusing the old pistons isnt as great as buying new and having the block bored,but its not all bad though. Im pretty sure the engine is probably burning a little oil at this point since the rings havent really had time to seat properly. Give it a couple hundred miles but be sure to check your oil often to see how much you might be buring .
Ususally after a rebuild using the same pistons the engine will burn oil its pretty common actually. the pistons do not wear round perfectly in the bore so when putting new rings in the rings are perfecly round so there is going to be oil blowby the rings. That would explain most of your smoking problem if you are absolutely sure your head gasket is fine.
Correct me if im wrong guys but im glad to help
Old May 21, 2008 | 05:24 PM
Saosinx's Avatar
Default Re: h22 smoking after rebuild? (H23VTECBB1)
i give a to H23VTECBB1 and to Apex1972 for making me laugh lol so true.
Old May 21, 2008 | 06:43 PM
98vtec's Avatar
moderator emeritus
ring gap?
piston to wall clearance?
block rehoned?
rings clocked upon install?
compression test?
leak down %?
miles on engine?
type of oil?
a bad egr can cause detonation, not engine knock.
sounds like to me that you took a "mechanics" word for it.
Old May 22, 2008 | 02:47 AM
Default Re: h22 smoking after rebuild? (98vtec)
thanks H23VTECBB1, that really helped me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">ring gap?
block rehoned?
compression test?
leak down %?
miles on engine?
type of oil?
sounds like to me that you took a "mechanics" word for it.</TD></TR></TABLE>
as for the egr valve not knockin, it does, read about egr valves when they go bad one of the symtoms is "pinging or knockin".....anyways i just orderd a egr block of plate....
anyways thnks everyone (specially H23VTECBB1
lol)
Old May 22, 2008 | 06:45 AM
98vtec's Avatar
moderator emeritus
detonation = ping
is that really the only question you are going to answer?
Old May 22, 2008 | 10:07 AM
Apex1972's Avatar
I am not the one from Haterstown dude. I was only stating the truth. Why would anyone use that many new parts and then reuse the old pistons? Would you? From the sound of the OP, he sounds like he used pistons from a different block alltogether definately FTL!!!!
Modified by Apex1972 at 11:19 AM 5/22/2008
Old May 22, 2008 | 12:19 PM
98vtec's Avatar
moderator emeritus
if they are still within the service limit, you dont need new pistons and replacing the rings will suffice as long as they are gapped properly and clocked.
Old May 22, 2008 | 12:45 PM
Apex1972's Avatar
Yes this is true, but what if he has A size or B size? What if he has a block that has A and B cylinder bores? Maybe he needs to be sure what he has.
Old May 22, 2008 | 01:53 PM
the problem was that i took the mechanics word wen they told me my engine was knockin because one of my wrist pis was bad so i got all the pistons changes, and i now i figured out that it was my egr valve.... anyways thanks everyone
RPMvulocity
Jul 12, 2010 02:25 PM
H9Omega
16
Dec 14, 2006 06:28 PM
AzNpRiD3
Jun 25, 2004 08:05 PM
SBCCIVIC
Jun 20, 2004 07:36 PM
SymphonyX
Mar 18, 2003 09:52 PM
