Turbo Civic Wont start?
Ill post the setup later maybe. It has only done it today and I have only had the car a week so I dont know very much.
When i start it i have to rev it hard to get it then it will idle but after a while the idle gets lower and it dies. It bogs alot and dies at corners. I think it might be spark plugs. What are some good spark plugs for turbo setup and Ill go buy some and replace em all..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slo_ej8 »</TD></TR><TR><TD CLASS="quote">youll probably have better luck in the FI section. good luck</TD></TR></TABLE>
I bet it has nothing to do with his forced induction. Sounds exactly like a vacuum problem. i would really check out the hoses around the Intake Manifold especially.
Could be: bad fuel filter, shitty fuel injectors, wrong ECU / not properly tuned ECU, horrible condition spark plugs... You need to get one STEP colder spark plugs for each additional 100HP that you are making over stock. Get NGK's.
I got new ngks 1 colder and it made it worse. I talked to a friend and said that they had the same problem. They said there distributor broke or went out. could this be it? Cause it gradually got worse.
thanks
thanks
Very possible, then again it could be a number of things......That is the one bad thing about buying/doing swaps its harder for you to figure out what is goin on with you vehicle.......See if it is the distributor, if not then I recomend checking the fuel pump and filter.
so how would I know if it was the distributor. Any way I could tell if I took the cap off? I dont think the fuel filter when make it that bad all in one day. The fuel pump might if it burn up, but I dont think it is. It just seems like timing somewhere cause I can rev it to get it to start but seems like its running on 2 cylinders.
i have the same problem.. i have a type r block with a fully built gsr head and when i start it it dies.. so i have to rev it until it gets warm .. after its warm it runs perfectly fine//
M2B4
Jan 29, 2007 08:25 PM
. Have the injectors checked and replace your fuel filter.
