Double checking valve stem seal install
Old May 21, 2008 | 11:47 AM
Agito's Avatar
Default Double checking valve stem seal install
Hey guys,
Just wondering if this looks correctly installed. All 16 seals have this small gap as seen in the mirror. They had resistance when pushing them on but other than that no clicking feel just kinda firmly slid into place. These are supertech seals.
Old May 21, 2008 | 02:48 PM
00b18b's Avatar
Default Re: Double checking valve stem seal install (Agito)
The trick with these is to use a 11mm deep socket. It fits nicely against the lip/edge of socket and tap it lightly with a small hammer
Old May 21, 2008 | 02:56 PM
Agito's Avatar
Default Re: Double checking valve stem seal install (00b18b)
Hi, yeah I did that too and it just didnt seem to want to move any further.
Old May 21, 2008 | 10:26 PM
wed3k's Avatar
as long as the gap is even on all sides and is there any way to try and rotate and push down on it? what type of assembly lube are you using? because thats a lot of lube
Old May 22, 2008 | 03:13 AM
non-VTEC's Avatar
they look fine. and you dont need that much assembly lube.
Old May 22, 2008 | 07:57 AM
Agito's Avatar
Default Re: Double checking valve stem seal install (non-VTEC)
awesome, Thanks guys.
Yeah I eased up on the lube for the latter ones haha
mithious
19
Apr 21, 2015 03:23 PM
TomCat39
22
Mar 14, 2015 05:50 PM
forsakenriceboy86
Dec 3, 2009 04:36 PM
Civicr2gs5
21
May 6, 2004 12:44 PM
Ryan C
Nov 29, 2003 09:23 AM
