ecu help *pics
Old May 21, 2008 | 06:57 AM
zdizzle's Avatar
Default ecu help *pics
I have a cel on and im sure its something to do wth these wires being loose, the ecu is real sentive to touch. Its smells nice n rich as well the car runs smooth after its warmed up and idles 800-900. Can any1 help me or point me n the right direction to fix these or replace it 96 cx wth b16
Old May 21, 2008 | 12:00 PM
zdizzle's Avatar
Default Re: ecu help *pics (zdizzle)
i guess its too much for honda tech
Old May 21, 2008 | 04:13 PM
technine's Avatar
Did you check for any codes?
Can't help you if you have not done that yet.
Old May 21, 2008 | 04:51 PM
GhostAccord's Avatar
Retrieve the CEL Codes first and fix them then look into getting the ECU tuned if it's chipped. If your P30 isn't chipped then your irregular idle is more than likely being caused by the CEL related problem or something else mechanical in the Idle air control system
Old May 22, 2008 | 10:41 AM
JeffBro's Avatar
That harness is a mess. Wiring diagrams are your friend... Go get a book on it and find out what all those loose wires are and make sure everything is wired properly first.
Old May 22, 2008 | 02:24 PM
J. Mills's Avatar
Default Re: ecu help *pics (JeffBro)
Without even looking at a wiring diagram something tells me the wires you have unhooked are for your IACV. Hook them back up color to color!
esurds
Jul 13, 2009 09:33 PM
jpar195
Apr 7, 2008 12:01 PM
rasinhell
Jul 11, 2005 07:48 AM
RexB16
Jun 3, 2005 10:33 AM
B00ST2nR
Apr 18, 2003 03:35 PM
