cooling problem
Old May 20, 2008 | 10:22 PM
lisajasmin's Avatar
Default cooling problem
i change radiator, radiator cap, and Thermos stac and bleed the system it still over heat but only when freeway driving i do not see white smoke or see oil in the coolant,so i dont think it is head gasket and also the fan works only thing left is the water pump is their any way i could check it or some test
Modified by lisajasmin at 9:56 PM 5/27/2008
Old May 20, 2008 | 10:52 PM
2wheelhunter's Avatar
Default Re: cooling problem (lisajasmin)
USUALLY with hondas when the thermostat goes bad they stick open causeing the engine to run cool and take longer to get to full runing temp.
sounds like your over heating.. it could be the thermostat but probably something else.. check for a coolant leak (a minor leak would cause an air bubble or vaporlock causeing it to overheat) or check the oil and coolant for a mixture then it would be a headgasket.. give those a check and then check back! good luck!
Old May 20, 2008 | 11:08 PM
obuhmyuh's Avatar
Default Re: cooling problem (2wheelhunter)
is your car overheating? i would imagine its your thrermostat, although its usually stuck open it might be stuck too which would cause it to overflow like that. thermostat is probably to blame and it a cheap/easy fix.
Old May 20, 2008 | 11:09 PM
obuhmyuh's Avatar
Default Re: cooling problem (obuhmyuh)
and make sure you have enough coolant in ur radiator and no air in your coolant lines.
Old May 21, 2008 | 05:57 AM
h2392si's Avatar
Try all the above, plus fan switch, radiator cap, make sure you're not loosing a lot of collant somewhere else. You can also try bleeding the cooling system as well. Might just be a bad thermo but can also be a bad waterpump/radiator, etc. Try the small things first.
Old May 21, 2008 | 10:31 PM
lisajasmin's Avatar
thanks i will check in to that also their is no heat coming from the heater
Old May 22, 2008 | 02:07 AM
vdawg559's Avatar
thermostat
Old May 22, 2008 | 09:22 AM
obuhmyuh's Avatar
sounds like its stuck shut.
Old May 22, 2008 | 09:28 AM
ho bag's Avatar
Just replace the t-stat for the few $ it cost and then rebleed the system properly.
Old May 25, 2008 | 10:40 PM
lisajasmin's Avatar
thanks
Old May 25, 2008 | 10:41 PM
lisajasmin's Avatar
Default Re: cooling problem (h2392si)
thanks
Old May 25, 2008 | 10:42 PM
lisajasmin's Avatar
thanks for help i will try all suggestions
Teamdiesel
40
Dec 3, 2019 04:10 PM
jlowellintegra
Jun 25, 2011 12:31 PM
96EkCivicBronze
Sep 12, 2006 10:22 AM
bostoncal
Oct 21, 2005 09:03 PM
meanTheDope
Aug 22, 2005 10:31 AM
