I got a good return line turbo question
Old May 20, 2008 | 08:43 PM
accord99power's Avatar
Default I got a good return line turbo question
Why couldnt you just run the return line on the turbo to the valve cover? why or why not. the oil still goes to the oil pan right?
Old May 20, 2008 | 08:46 PM
OMG B16's Avatar
Default Re: I got a good return line turbo question (accord99power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord99power &raquo;</TD></TR><TR><TD CLASS="quote">Why couldnt you just run the return line on the turbo to the valve cover? why or why not. the oil still goes to the oil pan right? </TD></TR></TABLE>
Return lines are gravity fed. Meaning, they need a downhill path to work properly.
Old May 20, 2008 | 08:50 PM
95dc2teg's Avatar
Default Re: I got a good return line turbo question (OMG B16)
^ what he said....that was a horrible question.
Old May 20, 2008 | 09:16 PM
morgan@synapse motorsport's Avatar
if your turbo was above the valve cover that could work lol. the return must be free flowing with little to no resistance back to the oil pan and must be gravity fed.
Old May 20, 2008 | 09:23 PM
GT35R_EF's Avatar
Make mine whatever you want
Default Re: I got a good return line turbo question (mike@synapse motorsport)
Old May 21, 2008 | 09:45 AM
EJ1 wilcox's Avatar
Default Re: I got a good return line turbo question (GT35R_EF)
Remote mount STS turbo kits drain the oil to the valve cover. Actually a fitting that you install into the oil cap. But they use a pump to pump the oil from the turbo.
I suppose you could do this with a traditionally mounted turbo if you wanted to use a pump to get it up to the VC. I'm not sure why you'd do this though.
jdmhondak9
Nov 6, 2012 07:32 AM
T9U4ReBgO
Nov 25, 2007 02:44 PM
"00"R
Jun 21, 2007 10:48 AM
TEG777
Jun 27, 2005 04:01 PM
StreetGlwLude
Sep 9, 2004 09:11 AM
