H22A AC Bracket... some picts
Old Jul 15, 2002 | 11:31 AM
Newman's Avatar
New User
Default H22A AC Bracket... some picts
Been out of town and busy with work, but finally got around to taking new picts of some kits and that sort. Since I've received so many emails regarding the AC bracket, I figured I'd show it in action. Here it is on an EK Civic coupe:
You can see that it easily clears the HCP front crossbar. It utilizes the SOHC 92-00 Civic AC compressor (so you don't have to refit your lines) and a 90-91 Accord AC/alternator belt. For the EK, you can use the same condensor fan on the AC condensor, but on the EG, you'll need a pusher fan infront of the AC condensor due to less space on the EG. Also, the stock Integra (B-series) AC compressor will not work if you put a H22 swap into your 94+ Integra. What you can do is use the Civic AC compressor, and have the Integra AC lines refitted to the Civic compressor. Works great and is on a couple of our cars.
Old Jul 15, 2002 | 11:39 AM
H22AMedina's Avatar
Default Re: H22A AC Bracket... some picts (Newman)
great how do I buy one? i have CASH, CREDIT, CHECK you name it how much ? 145 right?
Old Jul 15, 2002 | 02:59 PM
Newman's Avatar
New User
Default Re: H22A AC Bracket... some picts (H22AMedina)
Email or PM me for more info.
Old Jul 15, 2002 | 07:54 PM
LshatchTurbo's Avatar
New User
I knew I would see one sooner or later. Excellent job
Old Jul 15, 2002 | 09:02 PM
97hb's Avatar
Seems like jdmshit.com is on top of their game
Old Jul 15, 2002 | 09:33 PM
Jonathan_ED3's Avatar
Default Re: H22A AC Bracket... some picts (97hb)
awesome.
is a crossbar going to be available for EG's soon?
Old Jul 15, 2002 | 11:05 PM
H22AMedina's Avatar
Default Re: H22A AC Bracket... some picts (hot_EF)
Newman you've got mail
Old Jul 16, 2002 | 07:44 AM
Newman's Avatar
New User
They're in the works. I have a prototype bar but it's been slightly redesigned. I've only run with it a few times and had some clearance problems with my huge 4-1 Hotshot header. As for handling with the front bar, amazingly there wasn't really much more difference with it on. For the EG, the 3 solid mounts keep the motor from moving already... no vibration either. Now, on the EK, that's a different story... the driver's side gel-filled mount is weak and is prone to breaking under high stress applications (I've even seen B-series motor bust that mount), so the front crossbar is vital on the EK.
Old Aug 4, 2002 | 11:30 AM
ATS*EK24's Avatar
Fresh start for 09'
NEWMAN-
Are you the same guy who had the white eg with black front end and that B20 turbo set up in your signture box??
Old Aug 4, 2002 | 04:41 PM
racecarpete's Avatar
Default Re: H22A AC Bracket... some picts (JDMboy)
NEWMAN-
yep that would be him. He doesn't have it anymore though.
Old Aug 4, 2002 | 06:47 PM
ATS*EK24's Avatar
Fresh start for 09'
Default Re: H22A AC Bracket... some picts (SilverCivic2k)
Thanx "SilverCivic2k"
Just wanted to know cause i have done business with him before when i bought my HCP mount kit and MUGEN program for my swap in my old crx. He's real cool to deal with and get's you your parts when he says he will.
I like that HCP H22 swap kit!
I just might have to go for that swap and i will sure enough deal with "NEWMAN"!
delsoleg2
Mar 16, 2011 01:46 AM
Honda-bond
Apr 8, 2010 08:01 PM
sii.
Aug 30, 2007 09:48 PM
EgRaCeRB18C
Jan 29, 2004 06:32 PM
