LSD/locker on CRV
No, it's all automatic transferring power to where it needs it (Front to back, not from side to side). The grade logic program will take care of it for you, it's all automatic.
but.....
if i loose traction on the front and the power is sent to the back and i have a LSD/locker or whatever i will have more tranction in both sides not just in one side
the crv's front difference acts just like a regular open diff. And the rear diff or "dual pump" as honda calls is made up of sevral clutch plates instead of the normal diff. The torque split from the front to back is 90-10 but when the VSA system detects that one or more tires are sliping it moves the torque to the tire that has the most grip.it can be front to back or side to side.
Hello!
I am also looking for a locker for the front differential of Honda CR V- 2000.
For those four years - which the topic stay open - maybe something new came out?
Thanks in advance for any information!
PS.: I don't need LSD - I want to install locker.
