need help with tranny
Old May 20, 2008 | 03:18 PM
thedao's Avatar
Default need help with tranny
my fifth keeps poping out, and people told me that the reason is low fluid. and if thats is true. I can't find the fill hole and the drain hole. and last question how do i know how much to put in. please help a bro out.
Old May 20, 2008 | 03:42 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: need help with tranny (thedao)
Unthread this bolt to fill tranny, it has a crush washer behind it that should be replaced also. Fill it on level ground until oil spills out of the hole - fool proof.
The drain bolt is lower on the tranny and has a square hole that fits a 3/8" rachet.
Old May 20, 2008 | 03:46 PM
fastrc2's Avatar
if its pooping out of gear, check thoroughly all engine/ trans mounts, then check the shift linkages for proper sliding/pivoting action, then check the adjustment of the shift linkage. these all affect the gears ability to stay in gear.
Old May 20, 2008 | 04:19 PM
thedao's Avatar
cool thanks guys
Old May 21, 2008 | 04:57 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: need help with tranny (fastrc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastrc2 &raquo;</TD></TR><TR><TD CLASS="quote">if its pooping out of gear, check thoroughly all engine/ trans mounts, then check the shift linkages for proper sliding/pivoting action, then check the adjustment of the shift linkage. these all affect the gears ability to stay in gear.</TD></TR></TABLE>
He is right, forgot to say that tranny oil is probably not the problem.
bryanxwhite
Sep 24, 2008 05:02 AM
mugen mj5
Dec 17, 2006 02:19 PM
lsvtec90
Sep 28, 2006 02:47 PM
kixcrx
Aug 15, 2006 01:40 PM
rac3rb0i
Nov 30, 2004 11:02 AM
