Where is my primary o2 sensor harness?!
Old May 20, 2008 | 02:53 PM
HatchSpeeD's Avatar
Default Where is my primary o2 sensor harness?!
I have a obd-1 gsr motor swapped into an 2000 civic ex coupe from the prior owner. I've been fixing little things here & there to get all the CEL's cleared in order to pass inspection. I'm at one of the last problems which is hooking up the primary o2 but I cannot find the harness/clip for it. I've only found one extra clip that is four wire but it's a male plug & I believe on the engine harness side the plug for the o2 is female. Does anyone have any advice or can anyone tell me what color wires are on the engine harness side for the o2?
Eventually I might have to just get the pinout from the ecu & trace the harness but thats going to be a PITA! It looks like they used the stock 2000 obd-2b civic ex harness & modified with some integra plugs but I've yet to find the primary o2 clip. It could be cut but I'm hoping I can atleast find the wires to hook it up if it is cut.
Any tips & help would be apreciated.
Old May 20, 2008 | 04:55 PM
HatchSpeeD's Avatar
up for answers, GO CELTS!
Old May 20, 2008 | 06:24 PM
boost'd_crx's Avatar
Default Re: Where is my primary o2 sensor harness?! (HatchSpeeD)
it should be in the bundle of wires under the manifold by the vss plug.
Old May 20, 2008 | 10:49 PM
HatchSpeeD's Avatar
Yea I've checked around & will be searching again this weekend. Isn't the primary o2 on a 2000 civic EX more toward to front of the exhaust manifold though or is in the same location as a b-series? (right before the collector)
Anyone know the colors of the 4 wires on the engine harness side?
Old May 23, 2008 | 05:17 PM
HatchSpeeD's Avatar
Anyone else care to chime in with helpful info?
Only clip I got around the back of the manifold thats four wire is a male plug. Anyone know what color these four wires are?
stiffinEK
Mar 8, 2009 09:43 PM
FRKWOO
Nov 30, 2008 07:34 PM
TehMan
14
Sep 17, 2008 10:50 AM
sleeperek
Oct 24, 2004 08:50 AM
mjrage
23
Aug 16, 2004 10:12 AM
