Wierd auto tranny problem???
this might be a lil long, but bare with me.
So I have a 2002 auto civic. I bought an 01 auto tranny used off someone a while ago, and finally put it in last week.
First thing I noticed was the green circle beside the "D" was flashing. So the car was scanned (check engine was on, but its on 24/7 cuz im missing a oxygen sensor)
Got a code that was around the lines of "input shaft speed sensor". I read that a speed sensor code isn't always a speed sensor problem, but could also mean a mechanical problem inside the tranny. And my speedo//odo still works
Now, this "new" tranny slips like CRAAAAZY and I have no overdrive. So it kinda sucks when I'm constantly @ 4000rpm doing 130km/h on the highway, which is why I always gotta cruise around 80kmh/s @ 3000rpm. So I figured the D was flashing because I had no overdrive.
Now here's the odd part. Sometimes the D doesn't flash right away, and for that little bit that it doesn't start flashing, the tranny drives mint. Absolutely no slipping, perfect shifts, and the overdrive works. I went on the highway, it wen't into overdrive no problem, then after 1 minute, the D starting flashing the the tranny dropped out of overdrive and was slipping again all over the place
What could it be?
What could it be?
http://www.mediafire.com/?avyh7tyjtm0
Sounds like you're pretty much screwed. Like many of us with an 01-04 automatic.
