Help on a b16a1 Sir
Old May 20, 2008 | 12:59 PM
Coalmine's Avatar
Default Help on a b16a1 Sir
I have the option of buying a car this weekend with a b16aiSir full swap for my ef
the compression test was 150 160 190 190,
its not smoking at high rpm or when shifting ,
Could this just be the head gasket?
Old May 20, 2008 | 01:18 PM
all-mtr-teg's Avatar
Default Re: Help on a b16a1 Sir (Coalmine)
Run the car, and check the radiator overflow for air bubbles, if present then its probably a blown HG
Old May 20, 2008 | 08:52 PM
Coalmine's Avatar
Default Re: Help on a b16a1 Sir (all-mtr-teg)
will do thanx for the reply.
forgot to mention compression was done on a cold engine, i have no idea if that makes a diffrence.
Old May 21, 2008 | 06:59 AM
Was the test performed at Wide Open Throttle?
Old May 21, 2008 | 11:28 AM
Coalmine's Avatar
yes
Old May 21, 2008 | 11:48 AM
Well pour a teaspoon of oil into cylinders 1 and 2, redo the compression test, if the numbers jump up to the same level as cylinders 3 and 4, you know the rings are bad.
SilkyJohnson
13
Feb 15, 2011 05:54 PM
ej6kid
Dec 12, 2010 07:22 AM
94_civic_tuner
Oct 10, 2007 02:00 PM
JDM RHD eg6
10
Dec 24, 2006 10:51 AM
Brad
Sep 8, 2006 02:13 PM
