fuel pump problem
Old May 20, 2008 | 12:39 PM
mikester1222's Avatar
Default fuel pump problem
i have a 92 honda civic and i am putting a b18b into it i have a slight problem though there is no fuel preasure and when i turn on the key before trying to start it i dont hear the fuel pump start up! i changed the main relay and it still dose not work! what all could be the problem??
Old May 20, 2008 | 01:22 PM
Blk00EJ8's Avatar
Default Re: fuel pump problem (mikester1222)
Fuse?
Did you do anything to the pump or the related wiring since the last time it worked properly?
Old May 20, 2008 | 02:26 PM
Default Re: fuel pump problem (Blk00EJ8)
i checked all fuses and i didnt mess with anything with it! is there anything else that needs checked??
Old May 20, 2008 | 04:38 PM
reyracerx's Avatar
it was probably just time for the pump to die...just replace it. walbro recomended
Old May 20, 2008 | 08:04 PM
Blk00EJ8's Avatar
Default Re: fuel pump problem (reyracerx)
A pump rarely just immediately dies... it's usually a slow death that's characterized by intermittent failure.
I imagine you're using an Integra ECU with the LS motor in your Civic. Did you swap the pin on the harness to account for the difference between the fuel pump lead on a Civic (A16) to that of an Integra (A15)? That's probably your problem. Move pin A16 to A15 and you should have a priming fuel pump.
Old May 20, 2008 | 08:08 PM
IIXtremeHansen's Avatar
are all the plugs on the ecu side pluged up. if you leave a specific one out( the one outside the ecu) it will not start your car
Jay_Mills
Mar 16, 2012 10:05 AM
B16afmaxt
Mar 22, 2010 06:26 AM
93FlatBlackHatch
Dec 30, 2006 03:22 PM
92DXinMIAMI
Jun 8, 2005 06:43 PM
