head build ?
well guys its come time to start ordering parts for my first ever build and I got a quick question
can you mix and mach head parts for example can I order a zex cam, zex valve springs and retainers buy skunk 2 valves? or do I need to order all one brand, thanks George
That'll be fine. It's best to you the springs and retainers recommended by the manufacturer of your cam (which is what you're planning on doing), but using valves from a different manufacturer won't hurt. Of course, there's almost NEVER any reason to waste money on aftermarket valve... But you weren't asking about that, so I won't to into it.
well I am doing a build for turbo and a 55 shot of nitrous I am looking to hit 200-230whp without the bottle, would it still be a waste to upgrade the vaulves my motor as 190,XXX?
Aftermarket valves are not a performance upgrade, unless you're using them as an expensive and illogical way to alter your compression ratio. I recommend having the people who do the headwork install new oem valve guides and oem valves. The case for aftermaket valves doesn't really apply to your setup. They claim to minimize friction, but unless you're revving your motor passed 9000rpm (which you won't need to or want to), you won't need to worry about friction on the valves. The optimized flow characteristics they claim are unsupported and still don't make them worth their cost. You'd be much better off putting that money toward a proper port and polish.
thanks can I order ome valves at the local honda dealer ship? and has any one used comp cams and vavles springs, retainers and such on there turbo set ups? I was on there site today and I am thinking of ordering from them. any feed back?
You should be able to get the valves and valve guides at the dealership. What head are you building? I hear the best cams to use for boosted D's are the following:
ZEX (I know it's the 105300 for the D16y8)
Crower Stage 2 Turbo Cam
STOCK!
400whp+ has been achieved on completely stock heads. Your stock cam can generate just as much power as any of the aftermarket cams. The aftermarket cams will typically give you faster spool times, and will help correct reversion and detonation, if those problems are occurring.
What are your goals with this build? Is it for the street? Track? What kind of power are you expecting to get? Have you thought about your compression ratio? It's important that we know what you're looking for before we start recommending parts for you to buy...
STOCK!
BTW, you asked about Comp cams... Yes, they're a well respected cam manufacturer for a reason. ZEX is a subsidiary (don't know if they actually call themselves that) of Comp cams. Let us know what head you have and I can point you in the right direction for a few different cams.
goals: I am doing a turbo\ nitrous. I would like to get 200-230WHP without useing the bottle. I know that honda heads can handle a lot but I thought if I am going to do the block I should do the head at the same time. I called comp cams today about this package
http://www.compperformancegrou...D16Z6
It comes with cam, valve springs and retainers for $645
Yeah, I'm pretty sure that K59300 cam is the exact same as the zex 59300. That's typically the #1 recommended cam for D builds. Getting the full package from them sounds like your best bet. The springs they'll include were designed specifically for that cam.
About your goals, however, be sure to do thorough research into combining boost with nitrous. That may be overkill. I've only seen it done on drag cars with large turbos that spool very late and need the nitrous for low end, particularly in launching. I won't knock it if your goal is to be unique, but that setup, frankly, won't be practical for a street driven car. It'll also be very complicated to set up, tune, and maintain.
well My buddy is helping me along with this set up and he is awsome at tuneing hondas so tuning wise I not worried I think him and I can get this done I have a 55 shot of zex on there right now and it has taken me a year and a half to empty a ten pound bottle, I not exactly heavy on the pedal ethier I like to baby my car if you know what I mean. thanke very much for the help you have given me to and taking time out of your day to help me.
GReddyTurboCoupe
Jul 17, 2005 03:15 PM
white_n_slow
Jul 12, 2005 01:56 PM
