1000cc injectors??
Old May 20, 2008 | 07:18 AM
sevenj's Avatar
Default 1000cc injectors??
people talk about RC when they discuss injectors, anyone have anything against precision tune injectors??
injector caps change in size from 440cc to 1000cc??
Old May 20, 2008 | 07:20 AM
Luserkid's Avatar
Default Re: 1000cc injectors?? (sevenj)
Im running precision 1000cc injectors and also making 500whp right now (retune friday ). If your not making big numbers dont even think about them. But precision makes injectors between 440 and 1000. What are your goals?
Old May 20, 2008 | 08:41 AM
blk92_d16's Avatar
When I'll be looking more in depth at 1000cc injectors for my E85 build Precision and RC are at the top of my list. Guessing Presisions will be cheaper though...
Old May 20, 2008 | 08:45 AM
EkFG's Avatar
Default Re: (blk92_d16)
it all depend on your gaol and set up but. I have precision injectors but my build ie @ 400hp/ dynojet.
Old May 20, 2008 | 09:01 AM
sevenj's Avatar
Default Re: 1000cc injectors?? (Luserkid)
my goals are 600+ hp, built everything to do 600+ and now down to just needing injectors.
looks like I'm going to be surprised and will have to get a roll cage now.
precision 1000cc injectors need resistor box and I have a resistor box hooked up for my mitsubishi 440cc blue tops.
hoping that the 440 precision caps are the same fit as the 1000cc injector caps??
any knowledge on my mitsubishi 440cc injector caps working on the 1000cc precision caps...
Old May 20, 2008 | 09:02 AM
sevenj's Avatar
love what you had to say on the 17 looking for a first car...
precision is cheaper sounds like they are just as good...
Old May 20, 2008 | 10:07 AM
ekb16's Avatar
i believe RC needs a resister box also for the 1000cc...ive been researching bout that for my K build
Old May 20, 2008 | 07:49 PM
Luserkid's Avatar
Default Re: (ekb16)
Anything after 550s need a resistor box or an injector driver. What is 600+ that could be anything. If your looking to reach 700s i would move up to Bosch 1600s and a FJO Injector driver.
Old May 21, 2008 | 04:46 PM
sevenj's Avatar
Default Re: (ekb16)
the 440 mitsubishi injectors i have now are using a resistor box, I was told it would be sufficiant
Old May 21, 2008 | 04:50 PM
sevenj's Avatar
Default Re: (Luserkid)
really not sure what it will do??
built the bottom and top end for 40lbs of boost
going to run 30lbs
and the t70s good for 36psi
really not sure what horse power 30lbs in this project is going to produce??
CivicSi95
Feb 16, 2009 01:59 PM
Schister66
Apr 26, 2006 08:36 AM
boost_is_best
Feb 28, 2006 03:45 PM
VanHonda
Sep 16, 2003 08:47 AM
fortynineR
Jul 23, 2002 07:21 PM
