93 del sol sway bar link and rear trailing arm bushing question
First off I have a 93 del sol S non-dohc chassis. I have swapped over 95 integra upper control arms, knuckles, front brakes. Question is will the del sol lower arm and subframe support del sol si sway bar or largest size available without braces( dont know what largest size is). I would try it normally but I dont have a sway bar so I would have to purchase one and of course want to buy one bar.
I have also switched out the rear trailing arms with the integra for the disc brakes. I used the rear sway bar from the integra on the del sol no problem. I also have a question about using energy suspension replacement trailing arm bushings. How would keep the center from sliding around inside the bushing? thanks for the info
VTEC IS UR BEST FRIEND
Suspension & Brakes
Mar 10, 2008 12:55 PM
mafioso102
Jul 21, 2004 01:23 PM
phantom_sol
Apr 6, 2003 05:11 PM
