t25 disassembly help
Old May 19, 2008 | 12:16 PM
shaggyeg6si's Avatar
Default t25 disassembly help
okay so I have a t25 turbo off a saab 9000 and I want some help if you all don't mind. the center shaft broke on the turbine towards the exhaust impeller. I want to just replace the whole assembly mius the exhaust housing with my dsm 1g t25. my question is is the turbine shaft and the exhaust impeller one piece? if it is then I am screwed and this won't work. the exhaust a/r on the saab turbo is .51 and it is .49 on the dsm turbo. I already know that they are not compatable. but by taking the center section and compressor from the dsm turbo, put on the exhaust impeller from the saab turbo and exhaust housing. does this make sense to anyone?
Old May 19, 2008 | 01:27 PM
turbodano's Avatar
Default Re: t25 disassembly help (shaggyeg6si)
Yes the shaft and turbine wheel are one piece. I also don't think the DSM t25 turbine wheel will go into the Volvo turbine housing.
I might have some parts for you. Post some pics up when you get it apart.
Old May 19, 2008 | 01:45 PM
Default Re: t25 disassembly help (turbodano)
I already have it apart, but if the shaft is all one piece on the compressor wheel then i will just replace the whole turbo.
DAteg2
Dec 6, 2011 12:21 PM
Jackrabbit4
Feb 9, 2011 02:04 PM
muhaMan
Mar 21, 2007 05:49 AM
taggart_lumpy
Feb 16, 2007 11:13 PM
BlwnBlue
Oct 9, 2001 10:09 AM
