can you confirm ZC hp specs?
Old Jul 15, 2002 | 08:27 AM
daver's Avatar
Default can you confirm ZC hp specs?
I called a shop about he zc engine and he said he's got the SOHC and DOHC versions of the zc engine. He said the sohc makes 125 hp and the dohc makes 137? I thought there was only the dohc zc which made 130ps and the sohc version was the 108hp si motor we have here.
d
Old Jul 15, 2002 | 10:13 AM
DOHCtorJT's Avatar
Default Re: can you confirm ZC hp specs? (daver)
I thought the USDM DOHC ZC was 118hp and the JDM was 130hp
Old Jul 15, 2002 | 11:10 AM
CWBETB's Avatar
Default Re: can you confirm ZC hp specs? (DOHCtorJT)
There is no USDM ZC. The JDM DOHC ZC is 130hp
Old Jul 15, 2002 | 11:12 AM
daver's Avatar
I'm pretty sure there was no US dohc 4g civic. The best they sent was the sohc 108hp 1.6L Si. I found a link claiming the jdm zc engine pops out 137 bhp, so its true. It didn't say anything about their sohc version tho.
Old Jul 15, 2002 | 11:13 AM
reXem's Avatar
The USDM ZC is in the 88-89 Integras hence why a lot of parts come from that engine
Old Jul 15, 2002 | 11:18 AM
gregv's Avatar
Default Re: can you confirm ZC hp specs? (reXem)
from what I understand, "ZC" is a generic term, as the SOHC (D16A6) from the 88-91 Civic Si's is also a ZC, as is the DOHC JDM engine of the
same vintage (D16A8 & D16A9). The Integra units are also ZC's (D16A1). As far as horsepower goes, it depends which references you read,
and which market the engine came from.
Old Jul 15, 2002 | 11:40 AM
daver's Avatar
Default Re: can you confirm ZC hp specs? (gregv)
yep, i found another site claiming the dohc novtec "zc" has 130bhp. So does the old integra zc's have the same enige mounts as the 4g civic?
Old Jul 15, 2002 | 12:20 PM
gregv's Avatar
nope, but the Integra unit does drop into the 3G Civics. You have to get the JDM unit to use the stock 88-91 mounts, transmission etc.
Old Jul 15, 2002 | 12:48 PM
reXem's Avatar
ZC is ONLY the JDM one.....all others have a different block code D16A8 for Europe with a Cat D16A9 for Europe no cat....the JDM has ZC stamped as its block code.....ZC is not a generic term....
Old Jul 15, 2002 | 01:20 PM
gregv's Avatar
that makes sense, thanks for clearing it up.
Old Jul 15, 2002 | 01:38 PM
LoooseGSR's Avatar
I think the USDM ZC(D16A1) only has 118 hp...not really worth putting in if you ask me...
Old Jul 15, 2002 | 03:01 PM
Urban Business
Guest
Posts: n/a
Default Re: can you confirm ZC hp specs? (PSUCRX)
at the end of the day you still drive a 4th gen w/ a zc swap
Old Jul 15, 2002 | 03:08 PM
EF'n Fast's Avatar
Default Re: can you confirm ZC hp specs? (TorteX)
ExACTLY
Old Jul 15, 2002 | 10:17 PM
Magick211's Avatar
Default Re: can you confirm ZC hp specs? (EF'n Fast)
Jdm dohc zc's are around 129hp
GeoMetry
13
Nov 8, 2015 03:20 PM
sohcvtecowns
Jul 1, 2004 03:16 PM
1badrex
Dec 26, 2003 04:48 AM
itsJDMyo
Dec 13, 2003 10:57 AM
notfastenough
Nov 5, 2003 01:21 PM
