***Broke A Wheel Stud...Help***
Old May 18, 2008 | 10:42 PM
John 07's Avatar
Default ***Broke A Wheel Stud...Help***
I was rotating my tires today and one lug nut just wouldnt move. Eventually it just broke which is why im here. Is it an easy fix?? If so how can it be done?? How much do you think a dealer would charge me to fix this?? Im really not looking forward to drive just on 4 lugs. please help. thanks
Errr i really hope its not a serious problem.......
By the way it is the front left!!
Modified by John 07 at 10:57 AM 5/19/2008
Old May 19, 2008 | 12:42 AM
BlueIntegraBoy's Avatar
Default Re: ***Broke A Wheel Stud...Help*** (John 07)
I drove with 3 studs on my old hatch for a few months until I upgraded to Integra brakes. 4 > 3 studs
Old May 19, 2008 | 03:47 AM
eg6ajk's Avatar
if its rear wheel stud then its really simple to knock out the old one and press in a new one.
for the front, a hub will need to come out thus, requiring the bearing to be changed in most case or another way would be the less then perfect way, by shaving some material off the stud and knuckle.
http://www.youtube.com/watch?v=JAcMwPCI6a0
https://honda-tech.com/zero...age=1
Old May 19, 2008 | 04:47 AM
robfrmny21's Avatar
Default Re: ***Broke A Wheel Stud...Help*** (eg6ajk)
i just take a new stud and grand on it till it can fit part the back part of the spindle and then pull it in with a lug nut and washer
Old May 19, 2008 | 06:59 AM
get RIGHT's Avatar
OP, when you get it replaced you should invest in some anti sieze grease to help try and prevent this from happening again.
Old May 19, 2008 | 09:51 AM
citrus3000psi's Avatar
Default Re: ***Broke A Wheel Stud...Help*** (robfrmny21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by robfrmny21 &raquo;</TD></TR><TR><TD CLASS="quote">i just take a new stud and grand on it till it can fit part the back part of the spindle and then pull it in with a lug nut and washer</TD></TR></TABLE>
wow.
Old May 19, 2008 | 11:07 AM
Reid's Avatar
Global Moderator
Pull the spindle, press out the hub from the spindle, then press out the broken stud, and press in a new one. Installation is the reverse of removal.
Done.
Old May 19, 2008 | 11:20 AM
Dave-ROR's Avatar
Default Re: ***Broke A Wheel Stud...Help*** (citrus3000psi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi &raquo;</TD></TR><TR><TD CLASS="quote">
wow.</TD></TR></TABLE>
It works and is a common way to do it.
OP: replace them all if you do it the proper way. Even if the others aren't broken yet, you might as well just replace them. (on the one hub I mean, not all 20...)
Old May 19, 2008 | 11:33 AM
Default Re: ***Broke A Wheel Stud...Help*** (Dave-ROR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave-ROR &raquo;</TD></TR><TR><TD CLASS="quote">
OP: replace them all if you do it the proper way. Even if the others aren't broken yet, you might as well just replace them. (on the one hub I mean, not all 20...)</TD></TR></TABLE>
I wasn't saying wow to the reference of the procedure. I had to read that literally 5 times before it made sense.
MadVladCivic
Dec 3, 2015 06:50 AM
streetracer_305
18
Jun 20, 2015 01:59 PM
marvin75
Apr 24, 2011 05:48 AM
yh23
Suspension & Brakes
Jun 2, 2005 10:10 PM
Ninjaboi_on_X
Mar 16, 2003 07:14 PM
