Skunk2 intake manifold going in my eg6 with a 200 gsr...need advice
now the problem is not the installation i jus want opionions from ppl that have actually installed it.....
now i am hearing it is good to go with the type r throttle cable and the type r pulley the cable rides on...is this true? will i need anything else..? does the pulley jus bolt up easily? will i also need the throttle cable bracket that holds in place on the manifold?
thx need experinced guys who have done this themselves... thx guys
Modified by MontanaSFS at 9:38 AM 5/19/2008
you can reuse ur gsr bracket and throttle cable, it will work, however, i used to use a gsr bracket and throttle cable and it works fine, but u won't be able to put a strut bar on though. now i'm using a custom bracket with my single cam si throttle cable and works good. you can go ahead and use a b16 throttle bracket as well. if u can't find type r, just try to find a bracket and cable that will work together as a set and you should be fine. however, the type r does work good because the skunk2 manifold is just a replica of the type r. your also gonna have to zip tie ur evap control soloneiod sensor or make a custom bracket for it.
94cxhybrid-T
Dec 22, 2004 07:48 PM
fred92htch
Apr 7, 2003 07:55 PM
