Which throttle cable bracket to use
Old Jan 14, 2007 | 01:19 PM
IntegraTypeR's Avatar
Default Which throttle cable bracket to use
Hey guys,
my intake is a victor X and stock b16 throttle body and Type R throttle cable....now I tried both throttle bracket the one that came with the Type R cable and the one that came with the intake manifold and none of them seem to be right! now I tried flipping both around to check , but the closest was the Type R bracket with a nice cable grip BUT with the cable was touching the 4th piston runner! I don’t want the cable rubbing when I accelerate and decelerate!
so does anybody have pics of their victor X manifold with a stock TB?
thanks,
Km
Old Jan 14, 2007 | 03:36 PM
speedworks's Avatar
Default Re: Which throttle cable bracket to use (IntegraTypeR)
take the type r bracket, put one side of it in a vice and fold the tab that is sticking out in the opposite direction with a hammer or pliers. works perfect every time.
Old Jan 15, 2007 | 08:53 AM
Default Re: Which throttle cable bracket to use (speedworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedworks &raquo;</TD></TR><TR><TD CLASS="quote">take the type r bracket, put one side of it in a vice and fold the tab that is sticking out in the opposite direction with a hammer or pliers. works perfect every time. </TD></TR></TABLE>
thanks for the idea, but i already thought about using the P73 bracket, but no luck....i even put long bolts and used like 3 washers under the bracket and still there was a slight rub on the 4th runner!
well actually i solved the problem i modified the Victor X bracket using a vice and had to make like 2 mild bends with a 3rd bend at the fork area! its good now!
thanks for your concerns here
the cable should be tight enough not opening the throttle right? the helms says like 6-12 mm play? am not sure if its that important, but should i just look for that nice grip without the throttle opening?
existanzcivicb20
Mar 30, 2006 07:09 AM
JDM00SI
Jan 22, 2006 02:06 PM
zigs
Mar 2, 2004 12:24 PM
gsr98teg
Feb 6, 2004 02:06 PM
