H23 long blocks for sale (two)
Old May 18, 2008 | 04:20 PM
shandonwall's Avatar
Default H23 long blocks for sale (two)
Hey everyone, I am trying to get rid of 2 Prelude long blocks, one of them lost a rod bolt and damaged the rod journal on the number 2 cylinder, the other motor has a main seal oil leak (i think the crank is slightly bent, I thought thats what i saw) other wise its a good running motor with 139,xxx miles on it. The one with the lost rod bolt came from a engine seller, I have no idea how many miles are on it. If someone wants either or both, make an offer, or I can part them out. from pan to head, everything is there. No complete wire harness, only one cut harness (came with the motor from the seller). Has one set of accessories (power steering pump, alternator, starter)except air conditioning. Both heads still bolted down, nothing opened up execpt the oil pan on the one to inspect the rod journal damage. If you need the motor(s) or any parts off of them, let me know and make an offer, nothing reasonable will go unsold. Must clear out the H's to make room for the k24/20 swap.
ESP.net
Aug 19, 2012 05:49 AM
4npower
Feb 10, 2004 04:20 PM
ludesleep
Mar 12, 2003 09:56 PM
PreIudeSI
Nov 18, 2002 09:01 AM
