When do you use stands?
Old May 18, 2008 | 11:27 AM
Patman's Avatar
Default When do you use stands?
Debating on picking up a pair, could I get away with just a rear or is front pretty important too?
Old May 18, 2008 | 11:28 AM
marmaladedad's Avatar
I use mine whenever...
1) The bike is going to be out of commission for a while.
2) I need to remove the wheels.
3) I want to look like a pro-racer in the pits.
Old May 18, 2008 | 11:29 AM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
Default Re: When do you use stands? (Patman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Patman &raquo;</TD></TR><TR><TD CLASS="quote">Debating on picking up a pair, could I get away with just a rear or is front pretty important too?</TD></TR></TABLE>
i use my rear stand when i change oil, changing tires, cleaning chain, pretty much anytime im working on bike i like a rear stand. i use my cherry picker for the front just when im changing tires.
Old May 18, 2008 | 11:34 AM
GraphiteAccord's Avatar
Default Re: When do you use stands? (The Hooligan)
everyday.
My bike only utilizes the kick stand when it's not home.
Old May 18, 2008 | 04:11 PM
95ProjectEJ1's Avatar
Default Re: When do you use stands? (GraphiteAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GraphiteAccord &raquo;</TD></TR><TR><TD CLASS="quote">everyday.
My bike only utilizes the kick stand when it's not home.</TD></TR></TABLE>
Is there any benefit with the stands over the kickstand? I was thinking about getting a pair. I try and only ride my bike 1 or 2 days a week to keep the miles low.
Old May 18, 2008 | 04:19 PM
Default Re: When do you use stands? (95ProjectEJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 &raquo;</TD></TR><TR><TD CLASS="quote">
Is there any benefit with the stands over the kickstand? I was thinking about getting a pair. I try and only ride my bike 1 or 2 days a week to keep the miles low. </TD></TR></TABLE>
a bike on two stands has far less chances on falling on it's side.
Old May 18, 2008 | 04:39 PM
MSchu's Avatar
My Name is Nobody
I also use stands as a daily way to park my bike... it only takes a few extra seconds to put a bike up on the rear stand.
Old May 18, 2008 | 07:08 PM
a bike on two stands has far less chances on falling on it's side.</TD></TR></TABLE>
I figured as much. The first day I had my bike and put it on the kickstand I didn't get a warm and fuzzy feeling that it was very secure.
Old May 18, 2008 | 11:44 PM
bg-33p's Avatar
1. oil changes
2. chain maintenance
3. safer than kickstand
definitely worth it..even just a $50 dollar LP rear one will work.
Old May 19, 2008 | 05:35 AM
BrokeAssWhiteboy's Avatar
my house has wheels on it
My bike only utilizes the kick stand when it's not home.</TD></TR></TABLE>same here the hayabusa's seem to have a history of falling off the kickstand while parked.
Old May 19, 2008 | 05:48 AM
ucb's Avatar
ucb
Default Re: When do you use stands? (BrokeAssWhiteboy)
300 wide rear tire should help
Old May 19, 2008 | 05:54 AM
Default Re: When do you use stands? (ucb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ucb &raquo;</TD></TR><TR><TD CLASS="quote">300 wide rear tire should help </TD></TR></TABLE>
Old May 19, 2008 | 06:38 AM
LL2009's Avatar
same here.... i have the set of T-rex stands for $80 new of ebay, good ****....
Old May 19, 2008 | 08:32 AM
backlash's Avatar
I use the stands if:
I don't plan on riding the bike for a while and when I do ANY type of maint on the bike.
Oh yeah, when I had my bike in the back of a Penske moving truck, I had it on the stands
Old May 19, 2008 | 08:54 AM
rdblckSV650S's Avatar
Old May 19, 2008 | 12:05 PM
Gixx312's Avatar
Default Re: When do you use stands? (rdblckSV650S)
I use mine to clean the wheels, clean/lube chain, and m4d JDM pictureZ yo!
Old May 19, 2008 | 12:18 PM
MSchu's Avatar
My Name is Nobody
Default Re: When do you use stands? (Gixx312)
I use mine when I spray my chain with WD40...
Old May 19, 2008 | 12:19 PM
MSchu's Avatar
My Name is Nobody
Default Re: When do you use stands? (MSchu)
NOT!
Old May 19, 2008 | 03:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rdblckSV650S &raquo;</TD></TR><TR><TD CLASS="quote">
Is that such a bad thing that I dont ride my bike that often? The commute to work is 30+ miles each way...
Old May 19, 2008 | 06:29 PM
neof69's Avatar
My RC51 stays on a rear stand, and i only use the front when washing or doing an oil change.
Old May 19, 2008 | 09:33 PM
sporkcrx's Avatar
Default Re: When do you use stands? (neof69)
I just use the centerstand on it to lube the chain or change the oil real quick, no extra stands to buy
Old May 19, 2008 | 11:01 PM
IIRC, you're supposed to have the bike on the kickstand to help completely drain the bike. You can put the bike up on a stand after to help keep it level as you add oil.
Old May 19, 2008 | 11:02 PM
ucb's Avatar
ucb
Default Re: When do you use stands? (LL2009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LL2009 &raquo;</TD></TR><TR><TD CLASS="quote">
same here.... i have the set of T-rex stands for $80 new of ebay, good ****.... </TD></TR></TABLE>
werd, I got the trex units with the triple tee adapter too
Old May 19, 2008 | 11:27 PM
AzntaggeR's Avatar
TSPeed Factory
might as well get both considering its not that much more than just the rear stand
Old May 20, 2008 | 01:54 AM
Tornadom's Avatar
Default Re: When do you use stands? (AzntaggeR)
I use my rear stand anytime I am working on the bike, or washing/detailing it. If for some reason my bike were going to be parked for a while I would put it up on the stand as well, but I ride daily year-round so an extended downtime is not likely.
