b16 wont start after wire tuck. ugh.
Just finally "finished" a wire tuck on my b16 and now it wont start.. its an obd0 b16a1 with an obd1 dizzy and a p28 with hondata s300. It gets spark and it gets fuel.. Its got compression too. But it wont start. And i cant figure out why... When wiring the injectors i hooked all the colored wires up to the right pins on the ecu.. and the red/black wires coming out of each injector plug i hooked up to the injector resistor box. In no particular order. They dont need an order right? They just get constant power from the resistor box as far as i know. Am i wrong here?
And also i saw that i was getting spark at the end of the spark plug wires... but when i took the plug out and put it in the wire i had no spark..so i got new spark plugs. And didnt check to see if the plugs got spark after that it was too late last night... What would cause that?
What else can i test on the motor, or what are the next steps i should take to get it running?
And yes it cranks over and sounds like it wants to start.. but it doesnt.
Modified by ef dino at 9:01 AM 5/18/2008
you are correct...there is no order for the voltage side of the injectors...if i were you, I'd check the ground connection at the thermostat...sounds silly...but that is one of the main ground connections for the main pgm-fi relay. Just my .02. good luck...
