Help System too rich P0172 *check engine light*
Old May 17, 2008 | 01:38 PM
sky9's Avatar
Default Help System too rich P0172 *check engine light*
soo i just rented a autozone scanner and it say i "system to rich" p0172. i also just replace my old o2 sensor with a new oe denso o2 sensor. my CE light is sill on.
any help?
Old May 17, 2008 | 01:56 PM
sky9's Avatar
Default Re: Help System too rich P0172 *check engine light* (sky9)
p0172 bank 1
Old May 17, 2008 | 02:52 PM
Dramier's Avatar
Just curious, after replacing your O2 sensor, did you reset the ECM/PCM?
Old May 17, 2008 | 03:22 PM
sky9's Avatar
dont think i resetted the ecm or pcm? what are thos? i did unplug the battery
Old May 17, 2008 | 05:25 PM
Sean @ ESG's Avatar
Try unplugging the ecu and plugging it back in again.
I believe disconnecting the battery does the same thing though.
I'm pretty sure p0172 is picked up by the exhaust manifold o2 sensor - but if your engine IS running rich, just replacing the o2 sensor will not do anything. The CEL will still be thrown.
Old May 20, 2008 | 11:19 AM
sky9's Avatar
^ what can be done to fix this? gas prices are too high to be runing rich rite now.
D7KWagon
Nov 15, 2013 12:03 PM
VspecSiR
Mar 21, 2004 07:45 PM
bullet9925
May 29, 2003 05:41 PM
