clutch seems constantly disengaged
ive got the car up on jackstands and when i push the clutch in and put it in first, then let the clutch out, the tires wont move. pushing the clutch in and out doesnt seem to do anything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patrick4588 »</TD></TR><TR><TD CLASS="quote">ive got the car up on jackstands and when i push the clutch in and put it in first, then let the clutch out, the tires wont move. pushing the clutch in and out doesnt seem to do anything.</TD></TR></TABLE>
Is the car on? Can you spin the wheels yourself? Did you recently take out the axles or the transmission? What did you do recently that causes you to question the clutch?
well the axle was out of the tranny partially and thats why it was like that. new problem though, now its constantly engaged. i can shift into gears "ok" when the car is off, but when its on, the clutch is constantly engaged and i cant move it into gear (while the car is on the ground). its a competition clutch stage 5.
bled it a lot after work. clutch pedal feels great now, but still wont go into gear once the car is started. i guess its some kind of throwout bearing problem?
Modified by patrick4588 at 7:03 PM 5/18/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patrick4588 »</TD></TR><TR><TD CLASS="quote">bled it a lot after work. clutch pedal feels great now, but still wont go into gear once the car is started. i guess its some kind of throwout bearing problem?
Modified by patrick4588 at 7:03 PM 5/18/2008</TD></TR></TABLE>
Wow, did you really not replace that when you did the clutch?!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patrick4588 »</TD></TR><TR><TD CLASS="quote"> new problem though, now its constantly engaged. i can shift into gears "ok" when the car is off, but when its on, the clutch is constantly engaged and i cant move it into gear (while the car is on the ground). </TD></TR></TABLE>
you must mean the clutch is engaged while you have the clutch pdeal depressed?
what about when the clutch pedal is released and the car is on? still engaged?
you may have installed something improperly... the first time i did a clutch something simalar to this happend to me; i took out everything and reinstalled it again.. and it worked fine(my buddy said something could have been put in backwards? i never bothered to check, i just went ahead and reinstalled everything)
or try the throwout bearing... but while your doing that take a look in there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuNkDrSpOt »</TD></TR><TR><TD CLASS="quote">
Wow, did you really not replace that when you did the clutch?!</TD></TR></TABLE>
i did replace it. i think it either came off the fork or isnt lining up right on the pressure plate. when i take the transmission off, im going to re install the clutch and everything. hopefully all will be good tomorrow. and yes the clutch is constantly engaged, even with the pedal depresssed
SoullessJapaneseMachine
15
Feb 22, 2007 10:16 PM
