aem 30-1000 vs 30-1040
Old May 17, 2008 | 05:46 AM
magefa's Avatar
Default aem 30-1000 vs 30-1040
Hey guys, i have a 98 hatch with B16A2 swap...
can i user a 30-1000 box on it?
or should i get the 30-1040, whats the difference?
i connected the 30-1000 and the car started just fine...
Old May 17, 2008 | 06:50 AM
Turbo-charged's Avatar
Default Re: aem 30-1000 vs 30-1040 (magefa)
the older boxes are even more glitchy than the new ones. with the ecu in the car, and the key turned "on" you can just watch the sensors freak out. ive seen them work just fine....but i def. like a little more stability.
Old May 17, 2008 | 07:15 AM
magefa's Avatar
Default Re: aem 30-1000 vs 30-1040 (Turbo-charged)
Thnx for the answer,
let me see if i got it ,
the 30-1000 is older version and the 30-1040 is newer?
so what ur saying is that i better geth the 1040 right?
Old May 18, 2008 | 05:48 AM
Jared's Avatar
the 1040 is the newer box and is definitely more stable and less prone for random coil or injector driver burn out
Old May 18, 2008 | 10:55 AM
suspendedHatch's Avatar
Default Re: (Jared)
What are you guys talking about, "stable"? The software or the hardware? The software is independent of the hardware. I've been running a 30-1000 since 2001 and it's never been "glitchy" or "unstable". The software has come a long way and I just update it at each release. Yes, you are going to see the sensor readings with the key on. The raw TPS Voltage will fluctuate. That's not caused by the EMS, that's what the sensors are putting out. Is that what you are talking about?
Software version is V1.19 now (there's a 1.2 but the update was just for a specific non-Honda application). They've been working on a new software program from scratch. I like it but I'm more familiar with the old software so I'm sticking to that until the new one is out of beta.
The 30-1040 is the newer hardware version. They made the boxes smaller and it has more coil outputs than the original box. If you have a 30-1000 just use that; it's not going to matter. Get a gauge-type wideband controller too.
Old May 18, 2008 | 05:16 PM
Jared's Avatar
Default Re: (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">What are you guys talking about, "stable"? The software or the hardware? The software is independent of the hardware. I've been running a 30-1000 since 2001 and it's never been "glitchy" or "unstable". The software has come a long way and I just update it at each release. Yes, you are going to see the sensor readings with the key on. The raw TPS Voltage will fluctuate. That's not caused by the EMS, that's what the sensors are putting out. Is that what you are talking about?
The 30-1040 is the newer hardware version. They made the boxes smaller and it has more coil outputs than the original box. If you have a 30-1000 just use that; it's not going to matter. Get a gauge-type wideband controller too.</TD></TR></TABLE>
the hardware
Old May 18, 2008 | 07:51 PM
SuperTwinz's Avatar
Call up AEM tech support and find out if you have the lastest mods for that 1000 box. Depending on your setup, the 1000 box is way good enough.
ALL IMPORT
Oct 23, 2006 04:25 AM
jackhandy816
May 30, 2003 01:17 PM
Random.Hero
Oct 30, 2001 06:38 PM
