aem cdi ?
Old Oct 22, 2006 | 03:55 PM
ALL IMPORT's Avatar
Default aem cdi ?
i am now on my second cdi, the first wouldent let me rev past 8k.
now the second does perty the same but more so the tach output doesnt even work.
has any1 else had problems with this product. i am going to try & trade this in for a msd6 figure they are a little more reliable. just dont know what else 2 do.
if your wondering we have played with the dwel setting a little but no results.
aslo when u put the looper in it will rev right up perfectly
any opinions are welcome
Old Oct 22, 2006 | 05:04 PM
G2K's Avatar
G2K
Default Re: aem cdi ? (ALL IMPORT)
alot of people had alot of problems with the original cdi box. I know that the newer AEM Twinfire box is alot better. You should be able to talk to AEM and see if they'll fix the cdi or maybe upgrade you to the twinfire. The msd boxes are horrible, and everyone knows they burn out quickly. If all else fails you could check with tony1, I know he sells the M&W boxes
Old Oct 22, 2006 | 05:07 PM
ALL IMPORT's Avatar
thats what i have the twinfire cdi
Old Oct 22, 2006 | 05:14 PM
G2K's Avatar
G2K
You might want to talk to AEM then, I know a few poeple that have that box and it runs flawless.
Old Oct 22, 2006 | 05:29 PM
ALL IMPORT's Avatar
Default Re: aem cdi ? (G2K)
ive been dealing with them on it. i sent my first bos back they sent me a new box. & now the tach doesnt work on it. ive been dealing with henry from aem. do u know if your friends just wired it up & it worked of did they have to make it work. aslo what coils are they using.
i am using just 1 blaster ss coil for now. on my turbo b18
Old Oct 22, 2006 | 05:31 PM
G2K's Avatar
G2K
Most of the cars I've dealt with or seen are running individual coils, either CBR's or MSD SS. We also run the AEM EMS box and no distributors...so I'm not too fimiliar with anything else. I would definatly give AEM a call again, or try to find someone in the area that has used the box, and see if they can help trouble shoot it.
Old Oct 22, 2006 | 05:40 PM
ALL IMPORT's Avatar
i got the ems, & also am thinking of removing the dissy to eliminate that factor aslo but dont know how much is involved in the process
Old Oct 23, 2006 | 04:25 AM
G2K's Avatar
G2K
Just talk to tony1, get the cam trigger kit of his, its easy to install, and just follow the how to on either his webpage or on aem's page. Should help out bigtime But you'll end up having to either use the dizzy to distribute spark or run individual coils.
Boostednx
Nov 28, 2011 02:53 PM
lazyguy
Mar 15, 2002 10:22 PM
