help stalls on flat surface
Old May 16, 2008 | 11:39 PM
budget_hatch's Avatar
Default help stalls on flat surface
Hey peeps here we go ive got a ls hatch It was running great for months then it start sputering and gives a cel for code 43 fuel somthing i thought well the car has a gazillain miles so replace fuel pump and filter now it stalls when i get on flat surface
Ive tried a new relay im gona take fuel rail and injector off see if i can test and clean them other than that it just got a nw dizzy about few months ago had it got timed plugs the timing works help im stuck
Old May 17, 2008 | 12:04 AM
2slow4stock's Avatar
Does it start? Does it idle? Can you drive it? How much gas do you have in the tank. You need to be more specific...
I can't excatley (sp?) tell you what is going on. So you can drive fine on uphills and downhills then? But when you go to a flat surface it stalls?
Old May 17, 2008 | 05:41 AM
yup it starts but only when facing uphill any toher than that it stalls ive got a half tank if we rock the the car back a fourth itll start weird but
Old May 18, 2008 | 05:44 PM
IndySporty's Avatar
Default Re: (budget_hatch)
You should check continuity between fuel injectors and ECU pins. I had this same problem and the car ran like butt. When I checked the Injector wiring, the #1 injector had like 8 ohms of resistance between the injector wire on the harness and the wire at the ECU. I ran a new wire and it stopped throwing the code, started running right.
Old May 18, 2008 | 08:52 PM
What kind of fuel pump are you running? OEM or aftermarket? Any codes?
Old May 19, 2008 | 11:45 AM
nope no codes k i got it to stay running but now it wont run under half a tank and when i stop kinda fast it stalls ohhhh it ended being the fuel filter what was stoping it from running on down hill slopes
Ya i put new napa pump in the guy said itsa a little better 4 the swap he said??
nonpareil
Dec 25, 2009 06:29 PM
blake_mp
Aug 13, 2007 02:44 PM
ewing86
18
Oct 26, 2004 07:53 PM
