PLEASE HELP...
PLEASE HELP...
ok well im sad!!! I got my block all put together and now it will not start. I pulled the ECU and turned it over a couple of times to start the brake in. Pluged it in and tried to turn it over and got nothing. So started checking for fuel and spark. First fuel, thought I might be low on gas so I put in 1 1/2 gallons. Still the same. Put it back on and and primed it, and on the gauge at the FPR only got up to 1 psi. When I start it i get nothing. ? So im lost. I still have stock fuel pump. Have not touched it. All the same fuel parts. same ECU. i changed the fuel filter less then 10K ago. any suggestion will be appreciated ( not sure of spelling, sorry) and tried. thanks in advance. its a D16Y8 same ECU, have not touched fuel pump (still stock), I have not touched any thing that will effect fuel just pulled the old motor and put new one in. replaced the fuel filter less then 10K ago...
Re: PLEASE HELP... (blake_mp)
Check for spark first, if you don't get spark, the injectors will not fire because there is no crank signal in which to base a pulse off of.
Is your fuel pump priming? Is the regulator any good? You should hear it whirr a bit when the key is one for the first two secs, when the CEL comes on, and then turns off.
smileygreasy
15
04-19-2015 07:36 PM
EGNA
07-12-2006 03:31 PM
hair_rice
07-05-2004 07:37 PM
