GSR front brakes on EF??? yes i searched
Old May 16, 2008 | 11:23 PM
efhonduh's Avatar
Default GSR front brakes on EF??? yes i searched
i searched and couldnt find anything but have any of you guys put DC2 knuckles on an ef? i would like to hear some experiences/thoughts
thanks
Old May 17, 2008 | 05:23 AM
thevtecnician's Avatar
Default Re: GSR front brakes on EF??? yes i searched (efhonduh)
That will never work. I attempted to put the jdm 4x114.3 itr front kunckles on my crx and it was way wrong. The shape of the upper part of the knuckle is extremely different from the ef. the top of my tire was cambered out so far I couldn't drop the car back on the ground. Camber kits won't do it either
Old May 17, 2008 | 08:53 AM
boostedflaredb16si's Avatar
if most gsr knuckles are abs and thats why then will not work. but i think you can find 94 95 gsr or ls knuckle the will fit on an ef. the key ot that they have to be NON ABS. THJE ABS ONE HAVE A DIFFENT SHAPE TO THEM. i have ls one on my car and it fixes some of you camber depending on how low your car is. theres reallynot much of a diff. between the 2 brakes. i used a 13/15 master cly. from a 4 door civc. hope i was a help
Old May 17, 2008 | 09:20 PM
roastbeefrichie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efhonduh &raquo;</TD></TR><TR><TD CLASS="quote">i searched and couldnt find anything but have any of you guys put DC2 knuckles on an ef? i would like to hear some experiences/thoughts
thanks</TD></TR></TABLE>
the 94-00 integra uses calipers stamped 17cl14vn w/ 10.3" rotors. from what i've found is that the 94-00 integra knuckles work better on +92 civic. on 88-91 civic/crx knuckle upgrades, use the 90-91 civic ex 4-door or 90-93 integra knuckles for better results w/ camber, alignment & toe. the 90-93 integra knuckles (calipers also stamped 17cl14vn) & the 90-91 civic ex knuckles use bigger calipers & 10.3" front rotors. the 90-91 civic ex 4dr front knuckle is rare & expensive; the 90-93 integra front knuckles are easier & cheaper to find. if you plan on upgrading to integra da knuckles, you'll need to upgrade to a bigger master cylinder when using bigger front calipers since more fluid is required to push the larger piston...which can be found on a 90-91 civic ex 4dr. a 90-93 integra master cylinder & booster can be used as well.
https://honda-tech.com/zerothread/2140287
you can also keep the stock civic front knuckles and upgrade to an 11" rotor upgrade without having to swap to 90-91 civic ex 4dr or 90-93 integra knuckles. this set-up uses 11" rotors from a prelude re-drilled to 4X100 and cl brake calipers w/ machined brackets. plug and play bolt-on, pm brakeexpert for details...
https://honda-tech.com/zerothread/2211517
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thevtecnician &raquo;</TD></TR><TR><TD CLASS="quote">That will never work. I attempted to put the jdm 4x114.3 itr front kunckles on my crx and it was way wrong. The shape of the upper part of the knuckle is extremely different from the ef. the top of my tire was cambered out so far I couldn't drop the car back on the ground. Camber kits won't do it either</TD></TR></TABLE>
the itr lug conversion (4X114.3 or 5-lug) can be done on an 88-91 ef civic / crx using 90-93 knuckles. you'll have to press the new hub (4X114.3 or 5-lug) on new 90-93 teg front wheel bearings.
http://technet.ff-squad.com/how-to/5lug.ef-da/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedflaredb16si &raquo;</TD></TR><TR><TD CLASS="quote"> if most gsr knuckles are abs and thats why then will not work. but i think you can find 94 95 gsr or ls knuckle the will fit on an ef. the key ot that they have to be NON ABS. THJE ABS ONE HAVE A DIFFENT SHAPE TO THEM. i have ls one on my car and it fixes some of you camber depending on how low your car is. theres reallynot much of a diff. between the 2 brakes. i used a 13/15 master cly. from a 4 door civc. hope i was a help</TD></TR></TABLE>
^^^^^^^the 94-95 gsr or ls front knuckle without abs will fit on an ef beacuse it has different shape? ? ? ? ? ? wat?^^^^^^^^^^^
all 94-00 integra knuckles and calipers are the same (regardless if it is a gsr, ls, rs, gs, etc). all 94-00 integra front knuckles (EXcluding the integra type-r) use calipers stamped 1 7 C L 1 4 V N with 10.3" rotors. the only 94-00 integra that did not have abs was the integra RS. the 94-00 integra knuckle's geometry is best suited for +92 civic, but i have seen them on ef's. you'll have camber issues, but if you drop +2", your camber zeroes out, but you'll have no suspension travel.
https://honda-tech.com/zerothread/1508680
Old May 18, 2008 | 08:15 AM
Default Re: GSR front brakes on EF??? yes i searched (roastbeefrichie)
If you didn't know, the type-r's don't have abs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roastbeefrichie &raquo;</TD></TR><TR><TD CLASS="quote">the 94-00 integra uses calipers stamped 17cl14vn w/ 10.3" rotors. from what i've found is that the 94-00 integra knuckles work better on +92 civic. on 88-91 civic/crx knuckle upgrades, use the 90-91 civic ex 4-door or 90-93 integra knuckles for better results w/ camber, alignment & toe. the 90-93 integra knuckles (calipers also stamped 17cl14vn) & the 90-91 civic ex knuckles use bigger calipers & 10.3" front rotors. the 90-91 civic ex 4dr front knuckle is rare & expensive; the 90-93 integra front knuckles are easier & cheaper to find. if you plan on upgrading to integra da knuckles, you'll need to upgrade to a bigger master cylinder when using bigger front calipers since more fluid is required to push the larger piston...which can be found on a 90-91 civic ex 4dr. a 90-93 integra master cylinder & booster can be used as well.
https://honda-tech.com/zerothread/1508680</TD></TR></TABLE>
I know about the 4x114.3 conversion, but what ffs tech net doesn't tell you is that the 96 itr hubs don't fit the 90-93 bearings unless they are machined down. I didn't know this until it was too late, and just had them put back together and was gonna try it anyway and it of course failed. I learned the hard way!
Old May 18, 2008 | 07:40 PM
Default Re: GSR front brakes on EF??? yes i searched (thevtecnician)
(sorry to thread jack)
sorry to hear that.
...so what ended up happening & what knuckles are currently on your EF.
did you end up going 4X114.3?
using the 90-93 integra knuckles in 4X100? &lt;&lt;10.3" or 11" rotor?
or did you go back to the 88-91 civic / crx knuckles?
https://honda-tech.com/zerothread?id=1079051
http://battlecat.8m.com/ITR%20...A.htm
* all 94-00 integra (including the type-r) have abs. the only 94-00 integra without abs is the RS model *
http://www.itrsport.com/specifications.html
Originally Posted by EG6-DC2
First, let's get the types of units out of the way:
JDM ITR's:
96-97 had the OLD style of ABS units
98+ had the NEW style ABS unit
USDM ITR's:
97-01 ALL had the NEW style ABS unit
Next, let go over the differences between the old and new units and why their componants aren't compatible with each other.
OLD units - Were a 3 zone system, which means that it controls the 2 individual front brakes with separate but both of the back brakes are one zone together.
NEW units - Are a 4 zone system, one zone for each corner of the car.
The wiring harnesses are completely different between the 2 units. I can't quite remember which one had the plug with more pins in it, but they do not nor will they connect with each other in any way. In order to switch them out, you will need a complete system, which involves all of the harness and ECU's, etc... You will also need to know how and where certain lines splice into the dash wiring harness. You can not use a JDM wiring harness b/c that puts the ABS ECU right where you car ECU is. If you know USDM integra's, that is the reason why the ABS ECU is put in rear quarter panel area behind the plastics. JDM ITR's have their ECU's in the front kick panels.
Last, is the hardlines. The OLD unit is obviously a lot bigger than the NEW style(that's the reason why 96-97 ITR's never came with HID lights ), so the hardlines will not work with one another. You can either buy new ones for the specific style you are using or have someone bend you some custom ones.
ok. back on topic:
Originally Posted by boostedflaredb16si
94-00 integra knuckles will not work. but i think you can find 90-93 integra knuckles the will work on an ef. * the key is that they have to be from a 90-93 teg. THE 94-00 integra knuckles HAVE A DIFFERENT SHAPE TO THEM. i have 90-93 integra DA knuckles on my 88-91 civic/crx and it fixes some of your camber depending on how low your car is. theres really not much of a diff. between the 2 brakes (they're both stamped 17cl14vn). i used a 13/15 master cly. from a 90-91 civic EX 4 door.
:fixed:
Old May 19, 2008 | 06:00 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roastbeefrichie &raquo;</TD></TR><TR><TD CLASS="quote">(sorry to thread jack)
sorry to hear that.
ok. back on topic:
:fixed: </TD></TR></TABLE>
I ended up going back to stock in front, and ls in the rear. I'm gonna be using da knuckles with itr calipers and redrilled rotors though. Check out my build in my sig
Old May 19, 2008 | 10:00 AM
EL Vap133's Avatar
Here is how I made them work on my 88 CRX. I got all the components off (rotors, calipers, caliper brackets, pads, etc.) of the GSR knuckles, then I sold the GSR knuckles and used that money to purchase 90-93 Integra knuckles and swapped the components onto the 90-93 Teg knuckles. The car has been stopping fine for the last 4-5 years with no problems.
Old May 19, 2008 | 03:43 PM
efhonduh's Avatar
Default Re: GSR front brakes on EF??? yes i searched (EL Vap133)
i like your idea but did the DA Knuckles cost more then what you sold your gsrs for???
Old May 19, 2008 | 07:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Here is how I made them work on my 88 CRX. I got all the components off (rotors, calipers, caliper brackets, pads, etc.) of the GSR knuckles, then I sold the GSR knuckles and used that money to purchase 90-93 Integra knuckles and swapped the components onto the 90-93 Teg knuckles. The car has been stopping fine for the last 4-5 years with no problems. </TD></TR></TABLE>
the 90-93 DA,94-2001 DC/DB integra(excluding the type-r), 90-91 civic ex, 1996 itr all use the same exact caliper(down to the part#), and same exact size rotor.
My question is why would you buy two diff knuckles and switch parts around when you can buy complete 90-93 DA knuckles and slap them right on without having to swap anything?
And FYI* my 1996 itr front and rears did not have abs. When we put them onto my freinds 98 gsr(equipped with abs) we couldn't hook his abs up because there no threaded holes to bolt down the lines.
Modified by thevtecnician at 8:43 PM 5/19/2008
Old May 20, 2008 | 10:03 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efhonduh &raquo;</TD></TR><TR><TD CLASS="quote">i like your idea but did the DA Knuckles cost more then what you sold your gsrs for???</TD></TR></TABLE>
Not at all, they should go for about $25 a piece and up, depending on where you buy them. I bought them here: http://www.car-part.com
I sold the GSR knuckles for $100.
And FYI* my 1996 itr front and rears did not have abs. When we put them onto my freinds 98 gsr(equipped with abs) we couldn't hook his abs up because there no threaded holes to bolt down the lines.</TD></TR></TABLE>
I used the newer 96 GSR brake components because they are newer, less wear and tear and the 90-93 Integra knuckles I had gotten did not any brake components on them. I already had the 96 GSR front brakes in my possesion.
Old May 20, 2008 | 02:13 PM
mike-y's Avatar
Modified by thevtecnician at 8:43 PM 5/19/2008</TD></TR></TABLE>
JDM ITRs did not have ABS (or at the least, it might have been optional). All USDM ITRs came with ABS, regardless of year.
I am using 90-93 DA knuckles, hubs, rotors on my EF. They work perfectly. The DA arm is about 5mm taller than the EF arm, so alignment differences are negligible (just re-use the EF upper A arm), but I have a camber kit for a more aggressive alignment.
For the rear, I am using '96 DC integra trailing arms and brakes. The integra rear hub is a little larger than the 91 CRX hub with disc brakes, so the rear wheels will stick out like 3/8" to 1/2" more than if you used the CRX parts. Unless you have wide, low offset wheels, you shouldn't rub though.
Old May 20, 2008 | 03:14 PM
1989CivicSi's Avatar
Default Re: GSR front brakes on EF??? yes i searched (mike-y)
Just for archive information, 1996 4x114.3 ITR's did have ABS as a factory option. I have the conversion sitting at my apartment with the ABS lines still bolted up but cut -- front and rear
Old May 20, 2008 | 06:47 PM
boost'd_crx's Avatar
the only ones that would fit onto the ef are the ex or sir model hubs and da's. I have da's on mine works great. i got them complete for $50 about 6 years ago from a junkyard.
Old May 21, 2008 | 07:08 PM
o-man's Avatar
From: living too close to Karl, everythings busted, nc
Default Re: GSR front brakes on EF??? yes i searched (boost'd_crx)
http://www.fastbrakes.com
Had an 11inch upgrade using GS-R calipers. On my CRX for 1.5 yrs with no issues. Plus, no redrilling rotors
Old May 22, 2008 | 04:41 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
Holy crap man... mods should be able to take away points for blatantly wrong information. Especially in something that can effect tire wearing and steering characteristics so drastically.
I've used a DA front knuckle and brake assembly for 2 years now w/ brembo blank rotors and hawk pads.... no issues whatsoever.
Old May 22, 2008 | 02:46 PM
efhonduh's Avatar
Default Re: (ComeOnKip)
ok well since you seem to know what is wrong can you add some info
ssmrico
Apr 27, 2017 12:46 PM
HStockSi
15
Feb 21, 2006 02:48 PM
EF9Civic
13
Mar 13, 2004 07:46 PM
Boostage
26
Dec 12, 2003 03:19 PM
Fred n J_v2.0
May 2, 2003 01:14 PM
