92 CX rear DISK breaks?
Old May 16, 2008 | 06:57 PM
pliskin679's Avatar
Default 92 CX rear DISK breaks?
i had a SI and it had read disk breaks. my current CX has drum breaks and i hate them. is it possible to swap out the rear breaks with SI breaks?
Old May 16, 2008 | 07:10 PM
geebs's Avatar
Default Re: 92 CX rear DISK breaks? (pliskin679)
yeah you can swap them.. either by swapping the trailing arm and ebrake cables and brake hoses, or by removing the hub, bearing, and brake setup from each trailing arm.
Old May 16, 2008 | 09:22 PM
Mike_C's Avatar
what do you hate about them? the only benefit disks have are better cooling (if you're overheating your rears you need to learn how to drive anyway) and easier maintenance.
also... BRAKES.
Old May 16, 2008 | 10:03 PM
Hanmin's Avatar
si brakes seems to work way better than cx and vx brakes imo. when you press it you get a reaction alot faster than the other ones.
Old May 16, 2008 | 10:08 PM
Mike_C's Avatar
then the drums are not adjusted correctly. or (i've been out of the tech stuff for a while) it has a larger m/c.
Terrible One
Mar 1, 2009 04:46 PM
_gurusan_
Dec 5, 2005 11:41 AM
MrTodd
12
Nov 4, 2004 07:59 PM
servion
11
Aug 13, 2003 10:34 AM
Jonny G.
Apr 8, 2002 12:43 PM
