piston timing concern
Old Jul 15, 2002 | 12:51 AM
LB CRX's Avatar
Default piston timing concern
a few weeks ago my timing belt skipped a couple of teeth and three valves were bent in the process. i took the head off and rotated the crank to see if anything was wrong with the pistons. i noticed that piston 1 and 3 went up at the same time, and so did 2 and 4. is this how its supposed to be? i thought they all went up at different times.
Old Jul 15, 2002 | 03:12 AM
tinkerbell's Avatar
Default Re: piston timing concern (LB CRX)
whoah freaky!!!!
1 & 4 go togetehr and 2 & 3 go togetehr,
it is a 4 stroke engine, intake/compression/combustion/exhaust...
intake and combustion both need the piston going down and
compression and exhaust need teh piston going up
i hope this clears up your dilema
(i also thought all hondas were pair 1 & 4 and 2 & 3????)
t..
Old Jul 15, 2002 | 07:37 AM
earl's Avatar
Bending a few valves will not change the order in which your pistons go up and down. If it ran that way before, it will run again.
Old Jul 15, 2002 | 08:08 AM
LB CRX's Avatar
Default Re: piston timing concern (tinkerbell)
sorry about that. i think it was 1 and 4, 2 and 3. i was just concerned because im still not sure why my timing belt skipped the way it did, and i thought it might have something to do with my pistons/crank.
Old Jul 15, 2002 | 02:45 PM
earl's Avatar
Look more toward a tired, out of adjustment timing belt or a poorly designed cam gears.
Bernalx713
Mar 15, 2014 03:34 PM
92hatchling
Mar 5, 2006 02:53 PM
91civicEX
Oct 18, 2005 03:19 PM
SleepyHF
Mar 23, 2004 11:25 AM
dclub01
Apr 21, 2003 11:45 AM
