OBD0-OBD1 question
Old May 16, 2008 | 11:50 AM
alexm's Avatar
Default OBD0-OBD1 question
I'm changing my OBD0 B18a1 to OBD1 and need to know if I need the thermostat housing from a 94+ Integra. My thermostat housing has no sensor on it because I believe it's on the back of the block. I'll be hooking up the motor with a OBD1 engine harness so I'm a bit lost in how it's going to work. Sorry if that's confusing, any help would be appreciated.
Old May 16, 2008 | 07:06 PM
nikitad's Avatar
Default Re: OBD0-OBD1 question (alexm)
you can extend that plug on the harness to the back of your block, it should work.
Or get another thermostat housing cover - whatever is easier for you.
Old May 17, 2008 | 08:13 AM
alexm's Avatar
Default Re: OBD0-OBD1 question (nikitad)
I looked at the thermostat housing from a 95 Integra with a B18b1 and it did not have a sensor either on it. My D16z6 has the sensor on the housing but is not interchangeable with my B. Do you know which vehicle I can pull the housing/sensor off? Car will be OBD1.
Old May 17, 2008 | 08:42 AM
nikitad's Avatar
nah, don't remember. as far as i remember thogh that sensor is not exavtly a sensor but a thermo switch for fan ot come on when coolant reaches particular temperature.
jemo1
Jun 5, 2013 05:55 PM
fv8s
Jul 29, 2010 05:12 AM
prettylew
Oct 16, 2007 09:05 AM
R6Boy69
Jul 5, 2003 02:51 PM
