turbo gsr wont start. need help
basic rundown is i have turbo gsr with 1000cc injectors and omni 4 bar map sensor. i have neptune rtp and i cant get it to stay running. sometimes it cranks for a second but is very rough and then dies.
well it idles. it idles like crap and sounds like its on 3 cylinders, but it idles. dies when i touch the gas. needs some adjusting done for sure.
same problem freshly built gsr cant get it to run start and just dies any gas given kills it i have a basemap from xenocron if it runs not longer than 20seconds then dies sounds like **** like something is misfiring but everything is correct trying to get running for a week now what do i do
thanks
thanks
are you running the appropriate battery offsets?
ignition timing synched?
datalog your sensor voltages and make sure they are all correct.
