how do I check for vacuum leaks?
Old Jul 14, 2002 | 10:59 PM
xXsarcasmXx's Avatar
Default how do I check for vacuum leaks?
My Idle is high and I went to a local performance shop and they seemed to think it may be do to a vacuum leak....so how do I check for one?
Thanks
Old Jul 14, 2002 | 11:16 PM
bryant's Avatar
Default Re: how do I check for vacuum leaks? (xXsarcasmXx)
use a skwirt bottle of water. spay it on vacume lines. when the ideal goes down there is your leak. or your vacume lines could be wrong.
[Modified by CR-X, 2:17 AM 7/15/2002]
Old Jul 14, 2002 | 11:22 PM
poison's Avatar
Default Re: how do I check for vacuum leaks? (CR-X)
i'm just following this guy here
Old Jul 14, 2002 | 11:26 PM
_Endless_'s Avatar
Default Re: how do I check for vacuum leaks? (poison)
does high idling constitutes vacuum leak? how about low idling or idling dropping to 500rpm then goes back to the ideal idle rpm when decelerating? thanks
weaslehunter1
Jan 26, 2015 03:49 PM
98IntegraLSNonVtec
May 23, 2006 05:29 PM
diymarc
Jul 28, 2004 09:09 PM
Spec R
Apr 8, 2004 10:26 AM
fe519
Nov 26, 2002 01:13 PM
