Extracting broken bolt- using Jb weld Instead of real welding??
Old May 15, 2008 | 09:10 PM
B20EF's Avatar
Default Extracting broken bolt- using Jb weld Instead of real welding??
One of my bolts which holds down the camshaft broke off. It's almost completely flush with the top of the head. I just read a trick about welding a nut on their and screwing it out. I have no access to a welder so how about JB weld? The bolts are only about 20ft/lbs. Think it's worth the effort to JB Weld a nut on top and try to screw it out?
Old May 15, 2008 | 09:19 PM
hard_boiled_EG's Avatar
Default Re: Extracting broken bolt- using Jb weld Instead of real welding?? (B20EF)
i honestly don't think it'll work...but doesn't hurt to try....your best bet is an easy out or left handed drill bit...if it was me and that piece doesn't require any seals and all it's purpose is, is to hold down the camshaft...i take a hack saw and put a line in the middle then use a flat headed screwdriver....
Old May 15, 2008 | 11:48 PM
Frickr's Avatar
Default Re: Extracting broken bolt- using Jb weld Instead of real welding?? (hard_boiled_EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hard_boiled_EG &raquo;</TD></TR><TR><TD CLASS="quote">i honestly don't think it'll work...but doesn't hurt to try....your best bet is an easy out or left handed drill bit...if it was me and that piece doesn't require any seals and all it's purpose is, is to hold down the camshaft...i take a hack saw and put a line in the middle then use a flat headed screwdriver....</TD></TR></TABLE>
i agree with what you said in the first part, but i dont recomend your second suggestion. your best bet would be to get a bolt extractor, left handed drill bit, whatever you want to call it, they are cheap, i paid $3 for my last one i bought. as far as using JB weld, as far as im concerned JB weld is "OK" for some quick fixes when you have nothing else like a small leak. but by all means isnt that strong. you would have about as much luck supergluing the nut on that thing. a few bucks spent on this tool will save you more in time alone in the long run.
Old May 16, 2008 | 02:19 AM
Hanmin's Avatar
I say just take off the other bolt or bolts, depending on what motor it is, that is holding down the cam shaft and just vice grip it and twist.
Old May 16, 2008 | 04:37 AM
B20EF's Avatar
Default Re: (Hanmin)
^^Problem is there is nothing sticking out. It broke so it sits flat with the top of the head. There is absolutely nothing to grip or dremel a slot into. But thanks for the advice guys, I'll be getting it out tonight, whatever it takes.
Old May 16, 2008 | 08:41 PM
Hanmin's Avatar
oooh, is it completely flush with the bottom half? that sucks,,,
Old May 16, 2008 | 09:20 PM
cashkeith's Avatar
just drill and tap get your self some good bits some oil to keep it cool and when drilling into metal drill slow
UserX826
10
Feb 21, 2009 10:02 PM
got_no_sol
10
Dec 28, 2007 12:29 PM
igo4bmx
Jul 8, 2007 12:10 PM
sacredc0w69
Apr 13, 2004 08:50 PM
david90
Dec 2, 2003 06:42 AM
