JDM B16a VTEC
Old May 15, 2008 | 07:05 PM
aojtin's Avatar
Default JDM B16a VTEC
Okay ive got a few questions before i start wiring my vtec harness. first what if the holes for the pins i need to plug into the ecu connectors are already filled?
second does a d16a6 from a 1988 honda crx have a knock sensor or does the JDM B16a not have one because everything is plugged into the back of my engine where there should be a plug the harness doesnt hook up to. heres a picture of what i think could be the knock sensor but im not sure. keep in mind the harness on the engine is from a d16a6
next what do the 2 wires do on this plug. i know it relates to vtec and oil pressure or something but i need to know what each color means so i can pin it to the ecu right
and the green plug is where it goes to
thanks for any answers
Old May 15, 2008 | 08:10 PM
traxxasx's Avatar
On ur last pic, the green plus is vtec oil pressure switch. The green wire is ground. red is the signal from ecu.
On the white clip next to the green one, if your vtec soleniod, that also is a single wire that goes to your ecu.
Old May 15, 2008 | 09:55 PM
GiT LaO'd's Avatar
Your JDM B16A has a knock sensor because mine does in my 1990 Integra RS. I had hell with the knock code since the shop that had done the swap on my buddies used to be 1990 Integra didn't wire it up correctly... He sold it to me for $500 because he was tired of it...Fixed it now though...So wire up that knock...
Old May 15, 2008 | 10:51 PM
CRX91SE's Avatar
Default Re: (GiT LaO'd)
1st pic is the knock sensor, and the plug goes the green plug on the last pic
Old May 16, 2008 | 02:22 PM
aojtin's Avatar
if thats the knock sensor then why does the harness from the d16 plug right into it?
Old May 16, 2008 | 02:33 PM
jdmboyef9's Avatar
Default Re: (aojtin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aojtin &raquo;</TD></TR><TR><TD CLASS="quote">if thats the knock sensor then why does the harness from the d16 plug right into it?</TD></TR></TABLE>
Because the plug you used goes to something else like your air idle control valve or tps...check all of the sensors on the back of the intake manifold because some share the same style plug. The 88-91 civic/crx does NOT come wired with a knock sensor in the states so you will need to wire it up.
Old May 16, 2008 | 07:59 PM
aojtin's Avatar
Default Re: (jdmboyef9)
yep it went up above on the manifold. thanks i found it. also where should i ground the vtec oil pressure switch ground to?
Old May 16, 2008 | 08:13 PM
zrickety's Avatar
ground it anywhere. all grounds on the car are essentially the same. i ran a new wire to mine and then grounded a few other things to it.
hey do you still need a pic of my engine bay with those diaphragms on the intake removed?
Old May 16, 2008 | 09:47 PM
aojtin's Avatar
Default Re: (zrickety)
yes and i really need one of vacuum lines because once i hook those up and put in my ecu im done!!!!
Old May 16, 2008 | 10:44 PM
CRX91SE's Avatar
knock sensor is single wire
Novtecdohc
Sep 8, 2005 09:10 AM
mugenracer
Apr 26, 2004 08:10 PM
LD_EGSICK
20
Feb 4, 2003 07:47 PM
STK B16
Nov 7, 2002 03:34 PM
Metal_SOL
Jul 20, 2002 04:08 AM
