wiring problem obd1 to obd2
Old May 15, 2008 | 02:20 PM
fastfu's Avatar
Default wiring problem obd1 to obd2
i have a 1995 vx 1.5 and i had a little accident where i blew the engine up, oil sprayed on to the exhaust manifold and cought fire
now im finally getting things sorted and have bought a new engine but the problem is that all the 92-95 engines are pretty high mileage now so i went for and engine from a 98 so i now have an obd2 engine loom trying to connect to an obd1 internal loom
everything all plugs together fine all except one plug, on the engine loom it has 6 wires (black, white, red, brown, blue and yellow)and on the internal loom its only 4 (red, brown, blue and yellow). is it just a matter of joining the red, brown, blue and yellow wires together and leaving the other 2 out ?
Old May 15, 2008 | 02:29 PM
dinko's Avatar
Default Re: wiring problem obd1 to obd2 (fastfu)
96+ civic are obd2. they have a ONE piece harness that goes through the firewall. this harness will NOT bolt into your car. use your stock harness that was in your car.
which ecu are you running?
what model (ex, si, dx?) is your civic?
Old May 15, 2008 | 02:34 PM
fastfu's Avatar
Default Re: wiring problem obd1 to obd2 (dinko)
in that case im even more confused as i know the engine came out of a 98 but the wiring loom is the same set up as my eg where the plugs for the engine loom are either side of the engine bay next to the suspension tops
Old May 15, 2008 | 02:55 PM
dinko's Avatar
whoever sold it to you might have given you the correct engine harness as well. can you post any pics?
Old May 15, 2008 | 03:09 PM
DTA-Zombie's Avatar
just swap back to your OEM harness
SSBP-GSR
Dec 21, 2018 10:06 PM
1 Fly SI
Sep 1, 2011 07:08 PM
despat
Apr 2, 2010 02:56 PM
everlasting1832
Jan 4, 2006 09:38 AM
civic_ekek
Aug 10, 2005 10:14 PM
