are these throw out bearings reuseable? pic inside
Correct me if I'm wrong but I don't think you should JB Weld the bearing to the fork. Isn't it held in place by a metal retention spring?? I know that mine was. And I was told to replace the throwout bearing and pilot bearing when I did my clutch and flywheel, so I would check with Honda on that one. I dont see why you couldn't if the bearing is quiet and smooth and your not replacing the clutch/flywheel. Just my $0.02
Re-usable is up to you, but why. Parts that wear should always be replaced if your in the area of the part, especially if it is difficult or time consuming to get to. If you have the trans off just go find a new bearing and be happy. You will be pissed if you put it back together and it has issues.
jb weld is a big negative captain. I would wait till someone has a new throw out bearing, its not worth getting everything all back together just to have it go out.
thanks guys i actually found one haha it was only 20. i got lucky, but i have 2 of those bearing and they broke in the same exact place. i wasn't sure if it was okay to make it so that those TINY clips werent the only thing fastening my t/o bearing to my fork.
sorry for the retarded post, but i was desperate.
crxpwr1
11
Oct 2, 2006 03:45 AM
