Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
k24?
Old May 14, 2008 | 09:50 PM
07galaxygrey4dr's Avatar
Default k24?
so, a local guy has a k24 that he built for a turbo to put in his ep3. it was from a crv and doesn't have the vtec head. he is trying to sell this (along with original internals) for a pretty reasonable price. being an opportunist, i would like to try to put the k24 bottom end under my head. i am not planning on trying to turbo the engine, just na with more grunt. --------------------the point of the thread is, would it be worth trying to get that bottom end without any way to tune it (i.e. kpro)?i thought about a tsx ecu since it's drive by wire to, but meant for the 2.4 liters. any idea?
Old May 15, 2008 | 05:14 AM
SIVIC 3's Avatar
if its a steal of a deal, why not? the k24/k20 is the new ls/vtec!
Old May 15, 2008 | 05:30 AM
IT GUY's Avatar
Default Re: (SIVIC 3)
what do you mean when you say "built for a turbo" ?
Old May 15, 2008 | 05:55 AM
Default Re: (IT GUY)
9.0:1 pistons, rods, headwork (i.e. ported head, valves and springs). he has all the stock internals as well. obviously i wouldn't have any use in the pistons for what i would want to do, but stepping up displacement is appealing. i am just not sure if i would be able to get this combo running properly (ecu). any suggestions?
Old May 15, 2008 | 07:27 AM
dirtySOHC's's Avatar
Default Re: (07galaxygrey4dr)
i've been trying to research this same thing and as far as i know you should be able to run the bottom end with the SI ecu.
things I wonder about is if the mounts are exactly the same. and piston to valve clearance.
also with the low compression pistons that are in the block you're looking at you may not be too happy with it. you'd definately get the bump in tq but the top end may be lacking.
Old May 15, 2008 | 08:21 AM
supreme08's Avatar
http://youtube.com/watch?v=-S6791SykOY
Old May 15, 2008 | 08:36 AM
Default Re: (supreme08)
sick...
sounds like it's falling off up top though....any dyno sheets for this car anywhere?
Modified by dirtySOHC's at 5:42 PM 5/15/2008
Old May 15, 2008 | 11:38 AM
ekb16's Avatar
u wont be able to tune ur motor to run right if u run the stock SI ecu..u would need to somehow convert to cable type instead of DBW and use a rsx ecu and kpro that to be able to tune it correctly
Old May 15, 2008 | 12:05 PM
IT GUY's Avatar
Default Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 &raquo;</TD></TR><TR><TD CLASS="quote">u wont be able to tune ur motor to run right if u run the stock SI ecu..u would need to somehow convert to cable type instead of DBW and use a rsx ecu and kpro that to be able to tune it correctly</TD></TR></TABLE>
you lose your speedo/gauge cluster if you don't use the Si ECU. MAF fuel injection has the ability to adjust to minor changes, but I don't know if it can adjust for .4L of extra displacement without using AEM FiC or something along those lines.
Old May 15, 2008 | 03:33 PM
Default Re: (ekb16)
he wasn't sure what ECU to run just for the sake of the swap. you'd obviously need some kind of tuning capability.
Old May 15, 2008 | 07:27 PM
i wasn't planning on using the 9:1 pistons, i figured, barring any clearance issues, i would use the 11:1 pistons i already have. i assumed the stronger rods wouldn't hurt. i was planning on using my head/intake manifold/oin pan(if it would fit with the engine being a little bigger). the tuning is my main concern. i just need a way to make it run right. i don't want to give up my 8000 rpm redline and not see a pretty good bump in performance.
Old May 15, 2008 | 07:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 07galaxygrey4dr &raquo;</TD></TR><TR><TD CLASS="quote">i wasn't planning on using the 9:1 pistons, i figured, barring any clearance issues, i would use the 11:1 pistons i already have. i assumed the stronger rods wouldn't hurt. i was planning on using my head/intake manifold/oin pan(if it would fit with the engine being a little bigger). the tuning is my main concern. i just need a way to make it run right. i don't want to give up my 8000 rpm redline and not see a pretty good bump in performance.</TD></TR></TABLE>
you're talking about the pistons out of the K20? if so they wont work in the K24. different bore sizes.
Old May 15, 2008 | 07:44 PM
...yeah, i guess not. okay, i could bump the compression a little with the crv pistons...
JDMDAtehbeast
Aug 11, 2008 03:17 PM
leroyb
Jul 11, 2008 06:18 PM
aznegg
Oct 7, 2006 11:57 PM
Unsought Devil
Jul 31, 2006 05:21 AM
streetlvlhatch
Dec 4, 2003 01:27 AM
